06-27-2018, 02:23 PM | #1 |
Rock Stacker Join Date: Oct 2016 Location: Us of a
| revo rod end question
Usually good at searching for answers but im drawing a blank on this one.... Looking to upgrade the stock rod ends on my kit scx2 to revo with incision balls. Question is will the standard revo rod ends work in place of the bent and off set stockers with out causing binding issues, and will the revo ends thread on to the set screws in stock kit links. Thanks for any help Last edited by Tufftf2; 06-27-2018 at 03:05 PM. |
06-27-2018, 02:42 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: revo rod end question
I used RPM Revo rod ends with axial width brass balls from vanquish on my Bomber and got rid of the bent axial ends. I had to use an SSD M4 spacer with each rod end to keep stock lenght. Just make sure you know the lenght of the rod ends you want to buy first. Sent from my Nexus 6 using Tapatalk |
06-27-2018, 04:27 PM | #3 |
Rock Crawler Join Date: May 2018 Location: USA
They worked fine for me, and I also used the vanquish brass balls.
06-28-2018, 05:34 AM | #4 |
Rock Crawler Join Date: Mar 2013 Location: Waukesha
I've got the straight ends on mine as well. No Ill effects from switching out the bent or offset ends. Sent from my iPhone using Tapatalk |
06-28-2018, 05:40 AM | #5 |
On most aftermarket links / rods, it's the links that are bent to align the rod end with the skids / axles. Sent from my Nexus 6 using Tapatalk |
06-28-2018, 05:58 AM | #6 |
Trying to be as budget freindly as possible and i like the look of stock links.
07-15-2018, 06:34 PM | #7 |
Just incase anyone is currious i did the upgrade. The traxxas 5347 rodends work well in most places. I used an m4 lockwasher from lowes (24 cents for 5) and it worked out perfectly for a spacer (the ssd spacers were out of stock everywhere). The only issues i had were on the rear outside links on the skid plate they have an offset that lowers the link horizontally and with traxxas ends the link was hitting skid. That being said i dont think it would be an issue with rtr skid and im also running shorter then stock shocks and and binding was at the very top of travel so with stock shocks it may not be an issue. Also the drag link uses offset ends that keeps it off the pumpkin, and it was obvious you would loose steering if you used straight ends. I had some fresh axial ones on an unused tree and the vanquish balls fit perfect, so time will tell if the stock rod ends hold up with decent balls. Hope this helps someone Photo was of offending links.... Sent from my SM-G955U using Tapatalk |
07-17-2018, 08:16 PM | #8 |
Rock Crawler Join Date: Sep 2015 Location: Lake Stevens
We used Traxxas 5347 Revo rod ends with the stock links. They come with steel hollow balls and work great (all straight). The Revo rod ends are 1.5 mm shorter than the Axial ends. SSD makes 1.5 mm spacers that fix the offset: https://www.amainhobbies.com/ssd-rc-...d00151/p577533 But no one seems to have them in stock. So we used 3 mm spacers with the right OD: https://www.amazon.com/gp/aw/d/B076HNZLPJ Here’s the links with the spacers installed. We put them on the skid plate end, but either orientation works fine. Sent from my iPhone using Tapatalk Pro |
07-18-2018, 04:56 AM | #9 |
Never occured to me to make up the diffrence all on one end lol....Guess i unnecessarily got the brass balls the traxxas ones would have worked there is only a tiny diffrence in width from vanquish and what come with rod ends. Sent from my SM-G955U using Tapatalk |
07-18-2018, 03:03 PM | #10 |
So I just got a set of the RPM version of the revo rod ends and MY GOD are they so much better. We need to stop recommending the Traxxas rod ends and recommend the RPM version instead. The real Kicker? THEY HAVE THEM IN LONG VERSION!!!
07-18-2018, 03:13 PM | #11 | |
| Re: revo rod end question Quote:
And LINK PLZ! Sent from my Nexus 6 using Tapatalk | |
07-19-2018, 11:59 PM | #12 | |
Traxxas Long Rod Ends | |
07-20-2018, 05:27 AM | #13 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
| Re: revo rod end question I'll give you my experience with those RPM rods in the long version, if you're using just one for each link install the long rod into the chassis side, not the axle, i've broken several ones that went into the axle and none of them going into the chassis, the reason i can think of this happening is that the long rod isn't strong enough to hold the rotational force exerted in the axle side, but it has no problem on the chassis side
07-20-2018, 05:38 AM | #14 | |
07-20-2018, 05:45 AM | #15 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
Why not put the right ones back on the truck? With the correct bends and just as strong if not stronger than revo ends.
07-20-2018, 05:59 AM | #16 |
Right ones as in axial rod ends? They break if you look at them for too long... Sent from my Nexus 6 using Tapatalk |
07-20-2018, 06:55 AM | #17 |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
I'm running samix stainless steel pivot balls on my SCX10II and the stock rod ends are holding up very well, haven't changed one since. The plastic pivot ball are garbage!
revo rod end question - Similar Threads | ||||
Revo and jato rod end lengths | hijakdgtr | General Crawlers | 6 | 08-04-2013 07:08 AM |
Revo Rod End Thread Size | JTTG | Newbie General | 19 | 10-26-2009 05:55 PM |
Revo Rod End Width Dimension? | chevihemi | General Crawlers | 6 | 02-23-2009 09:42 PM |
revo rod end size? | 4ONDFLR | General Crawlers | 6 | 01-06-2009 10:03 AM |
revo rod end problems | ttrmike | General Crawlers | 5 | 04-20-2005 08:38 PM |
