12-04-2018, 02:48 AM | #1 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
| SSD portal kit for SCX10 2 axle
That looks interesting, just want ro know how much ground clearance will the truck get Sent from my SM-G955F using Tapatalk |
12-04-2018, 05:02 AM | #2 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: SSD portal kit for SCX10 2 axle
12mm clearance. Details are on the product pages: Portal Knuckles for SCX10 II Pro44 Portal Rear Axle for SCX10 II |
12-04-2018, 07:54 AM | #3 |
I am only seeing advantages to this setup! Home run boys!
12-04-2018, 07:59 AM | #4 |
| Re: SSD portal kit for SCX10 2 axle |
12-04-2018, 09:02 AM | #5 |
12-04-2018, 09:04 AM | #6 |
12-04-2018, 09:28 AM | #7 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
| Re: SSD portal kit for SCX10 2 axle I haven't seen too many exploded input gears from the Traxxas portals and since those are sintered it's not surprise they would go first, especially when full throttle rollover recoveries commence. I think these machined gears will be fine if you respect the throttle like usual.
12-04-2018, 10:31 AM | #8 |
any reason for this? Note: We do not recommend using these on plastic AR44 axles with removable C hubs. |
12-04-2018, 10:51 AM | #9 | ||
| Re: SSD portal kit for SCX10 2 axle Quote:
I quoted it below: Quote:
12-04-2018, 05:00 PM | #10 |
Newbie Join Date: Nov 2018 Location: Maryland
Is the gearing 1:1?
12-04-2018, 05:18 PM | #11 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
12-05-2018, 12:09 AM | #12 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
Will these work on the SSD Diamond?
12-05-2018, 03:53 AM | #13 |
01-19-2019, 07:16 PM | #14 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
Daaaang it. I literally just built up full ssd pro axles and these come out right after. Havent even ran my axles yet lol. Looks like rim choices may be limited with these?? It looks very tight between portal and rim. |
01-25-2019, 07:03 PM | #15 |
Rock Stacker Join Date: Mar 2012 Location: Truckee
When will they be back in stock?
06-15-2019, 01:24 PM | #16 |
Rock Crawler Join Date: Feb 2015 Location: Brough, North East, UK.
This might have already been commented on, but can't find it via the search function. Has a complete front portal set up being released yet, or can we now use the front set up on a Pro44/Diamond axle? I am sorely tempted by these portals for my UMG10 build, but a little confused on the front end over what to use for a strong set up. |
06-15-2019, 07:43 PM | #17 |
concerning the inner axles can we just cut the end off other axles and put flat spots on them to fit? Is that bearing race the same as on it SCX10 II spindle? Sent from my SM-N950U using Tapatalk |
06-16-2019, 11:43 AM | #18 |
From what i read somewhere SSD was sayng they will be releasing a V2 version of these portals, to fix some issues. Hope I am not wrong
06-18-2019, 04:26 AM | #19 |
I'm still interested in getting some, just unsure on the issues with using them with Pro44's... I understand the issues, just unsure what parts to use to fix them.
06-19-2019, 03:50 AM | #20 |
Can't find the topic anymore, but I am pretty sure that was some issues with them. Maybe SSD can clear us out
SSD portal kit for SCX10 2 axle - Similar Threads | ||||
New SSD Wide Axle Kit for Yeti | SSD | Axial Yeti | 28 | 02-19-2017 08:17 PM |
RC4WD scx10 portal axle kit. | RustenPaines | Axial SCX-10 | 3 | 03-12-2015 02:51 PM |
