Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Any battery tray options for the raw builders kit?
Old 01-04-2019, 02:38 PM   #21
Default Re: Any battery tray options for the raw builders kit?
Ok, what's the trick here? There's no way the battery tray will fit.
Sent from my SM-N950W using Tapatalk
BashNSlash is offline   Reply With Quote
Old 01-04-2019, 03:48 PM   #22
indybama's Avatar
I turned mine sideways across the frame rails, not between them. I used the cross member that has the 2 holes in it the original batt tray was screwed too.
Sent from my SM-J327VPP using Tapatalk
indybama is offline   Reply With Quote
Old 01-04-2019, 03:56 PM   #23
Nailed it! Actually, I cut it
Old 01-09-2019, 07:32 AM   #24
intheworksrc.com
this would work well
intheworks is offline   Reply With Quote
Any battery tray options for the raw builders kit? - Similar Threads
Cherokee kit or Raw Builders Kit? Canít decide! twentyniner Axial SCX10 II 12 12-02-2018 09:14 AM
Raw Builders Kit Missing Diff Bearing smog Axial SCX10 II 17 11-29-2018 08:01 AM
SCX10 II raw builders kit-questions Spence Axial SCX10 II 2 11-11-2018 07:34 AM
** IN STOCK Axial Racing SCX10II Raw Builders' Kit ** RPP Hobby RPP Hobby 0 11-06-2018 02:39 PM
IN STOCK Axial Racing SCX10II Raw Builders' Kit! RPP Hobby RPP Hobby 0 11-02-2018 02:15 PM
