12-14-2018, 08:42 AM | #1 |
Quarry Creeper Join Date: Aug 2018 Location: Toronto, Canada
| Motor direction is not what I want
Hey guys, I'm hoping someone could shed some light here. I've been using a Traxxas 21t (reverse direction) motor with the XL5 HV Esc from Traxxas. Things were fine as far as I was concerned, but I replaced the motor with a new one and the can shows "rotation direction" but that just makes it go reverse. Switching the polarity of the wires or setting the Esc to throttle in reverse means the truck goes forward, but it's opposite of what the "rotation direction" indicates. Any harm in doing this? Edit : with the stock 35t Axial motor, I have to set my radio to reverse throttle for it to turn in the right direction. This doesn't seem right. Last edited by BashNSlash; 12-14-2018 at 08:48 AM. |
12-14-2018, 09:07 AM | #2 |
Quarry Creeper Join Date: Mar 2014 Location: san antonio
I don’t think there is any harm in it running reversed and changing your remote settings. I could be wrong though.
12-14-2018, 10:08 AM | #3 |
RCC Addict Join Date: Sep 2017 Location: The OC
| Re: Motor direction is not what I want
No problems at all. Unless you've got some advance timing built into the motor - it looks like one that could possibly be an option - some rebuildable ones can rotate the end plate.
12-14-2018, 11:00 AM | #4 | |
| Re: Motor direction is not what I want Quote:
Sent from my SM-N950W using Tapatalk | |
12-14-2018, 11:08 AM | #5 |
Pebble Pounder Join Date: Aug 2010 Location: Anderson, SC
There are notches in the bell that are used for different timing settings. When you reverse rotate those marks on the bell are of no use. Not a big deal. Sent from my iPhone using Tapatalk |
12-14-2018, 11:18 AM | #6 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
Its only a sticker, if you were to swing the end bell 180 degrees then it would be reversed, or if you swapped a wire. So long as you don't have a lot of timing in the motor it shouldn't matter. If you do then just re-time it. Holmes Hobbies has a great youtube video on how, when and why | |
12-14-2018, 11:51 AM | #7 |
Thanks for all the help and insight guys! Really appreciate it! Sent from my SM-N950W using Tapatalk |
12-14-2018, 11:52 AM | #8 | |
RCC Addict Join Date: Mar 2011 Location: easton
If you have to reverse the throttle to correct your steering, then you have the esc and servo plugged into the wrong channel on your receiver. Reversing the throttle should not effect the steering Sent from my iPhone using Tapatalk | |
12-14-2018, 12:05 PM | #9 | |
I think he means the armature spins(turns) to the right. I would hope someone would notice that turning the steering wheel makes the rig roll forward or reverse.But you never know, Ive seen worst on facebook. | |
12-14-2018, 01:10 PM | #10 | |
Also, I'm here as I write this Sent from my SM-N950W using Tapatalk | |
Motor direction is not what I want - Similar Threads | ||||
<iframe width="420" height="315" src="//www.youtube.com/embed/gYr-dbPEOnE" frameborde | boolean21 | Scale Videos! | 0 | 10-01-2013 09:39 AM |
guide to xr10 "! NOTE DIRECTION" | captain.roche | Axial XR10 | 2 | 09-17-2010 12:05 PM |
MRC "motor noise" and L-trail chassis "drive shaft" | joeel | Losi Mini-Rock Crawler | 6 | 03-04-2010 04:38 PM |
