02-17-2019, 11:00 PM | #1 |
Rock Crawler Join Date: Dec 2010 Location: tracy
| Shock question
I am building a scale f350 and wanting to run the rc4wd king coilover reservoir shocks on the front of the rig. But I do not see them in 90mm with reservoirs. Could I run them in 100mm form and use the springs for the 90mm version springs? Or any other opinions are great to hear Sent from my Moto Z (2) using Tapatalk Last edited by wcdfmt510; 02-17-2019 at 11:02 PM. |
02-18-2019, 06:48 AM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
| Re: Shock question
yes u can i would use some spacers inside the shock under the piston will make it shorter just keep in mind both sides need to be the same lenght when put togehther if u gonna use 90mm springs u will need a 10mm spacer inside shock but will work just fine
03-10-2019, 09:41 AM | #3 |
| Re: Shock question
So I. Was looking at the rc4wd king shock spring kits. And the lengths are the same for the 90mm and 100mm. The od and id is different. I don't get the lengths being the same Sent from my Moto Z (2) using Tapatalk |
Shock question - Similar Threads | ||||
shock question | hillbillyrc | Losi Mini-Rock Crawler | 1 | 01-20-2017 02:54 PM |
R1 shock question... | DBCFR | G-Made Crawlers | 5 | 01-30-2013 12:51 AM |
Shock Question | baker3 | Redcat Crawlers | 6 | 11-05-2011 07:39 AM |
shock question | EMUTT | Axial Wraith | 4 | 10-09-2011 08:27 AM |
shock question | Hillbillyrcer | Newbie General | 7 | 02-18-2010 11:35 AM |
