03-24-2019, 12:57 PM | #21 |
Rock Crawler Join Date: Dec 2010 Location: tracy
| Re: My SCX10.2 Motor and Tranny so far...
Are you gonna add plug wires? Could probably use like 24-28g electrical wire Sent from my Moto Z (2) using Tapatalk |
03-24-2019, 06:46 PM | #22 |
Pebble Pounder Join Date: Aug 2010 Location: Anderson, SC
Yes, I am planning on wiring plugs. That’s a good suggestion. It’s hard to know how much detail is good and how much is overkill. I grew up on model cars and customizing them to the hilt but I want to be able to take this out and get it dirty too. I don’t want it to be too much of a shelf queen. I think I am going to switch to the hard body Cherokee from the lexan though. I like the challenge the hardbody brings as well as detail. I build for my enjoyment and not competition anyway. Sent from my iPhone using Tapatalk |
03-24-2019, 07:09 PM | #23 | |
| Re: My SCX10.2 Motor and Tranny so far... Quote:
Sent from my Moto Z (2) using Tapatalk | |
03-24-2019, 08:18 PM | #24 |
My plan is to integrate the servo and radiator. Maybe hide the servo in/under the radiator. Sent from my iPad using Tapatalk |
04-15-2019, 06:33 PM | #25 |
| Re: My SCX10.2 Motor and Tranny so far... This is a AMC 4.0L i6, I designed and printed from the ground up. It houses a electric motor, single speed multi gear transmission and 4wd transfer case. It also has a non-functioning throttle body, water pump, power steering pump, alternator, intake w/ fuel injection rail, exhaust manifold, oil filter, distributor and a starter. It is still a work in progress... Sent from my iPhone using Tapatalk Last edited by gsgraber92; 04-15-2019 at 07:19 PM. |
04-17-2019, 02:38 AM | #26 |
Newbie Join Date: Apr 2019 Location: Houston
Very very impressive! I really like it. I like that it's not another V8. What 3D printer do you use and what material? Where do you get the shafts and gears? |
04-17-2019, 06:23 AM | #27 |
| Re: My SCX10.2 Motor and Tranny so far... |
04-17-2019, 06:51 AM | #28 | |
Yeah, I wanted to stay true to the Jeep XJ powerplant. There are several V8’s but to my knowledge only one other inline 6 out there. I actually started from the transmission and worked my way both directions. I use a modified Maker Select i3 Plus (Wanhao) and I use PLA Plus. I used the SCX10.2 kit transmission parts. I did add a couple extra bearings for more support. I also use a 5mm ID pinion drilled through and use a threaded cross pin to secure the gear. Sent from my iPhone using Tapatalk | |
04-17-2019, 06:53 AM | #29 | |
Yes. It is a 45t 48p 5mm ID Robinson Steel Pinion. Sent from my iPhone using Tapatalk | |
04-19-2019, 09:00 PM | #30 |
Here are some of the 3D shots to show the internal details. Sent from my iPad using Tapatalk |
04-23-2019, 06:57 AM | #31 |
Quarry Creeper Join Date: Nov 2010 Location: land of no rocks
Wouldn’t be hard to make the serp belt functional. Some small screws and brass tubing as bushings. Add a small servo motor inside the ac compressor. It looks like the pulleys are already separated from most of the components anyways. Would give it that one extra bit of realism that most don’t have. Sent from my iPhone X using Tapatalk |
04-23-2019, 07:05 AM | #32 |
I did make the pulleys separate so the belt could be added on as a separate part. I used 4mm black elastic from the local craft store. I used E6000 glue to attached the belt ends. Strong and flexible. I didn’t however thing of making them move. Originally I printed the belt as part of the pulley layout but decided I wanted silver pulleys while most of the components were black or silver. I might look at the possibility of doing that. I’m not sure I have room for anything else in the block. Sent from my iPhone using Tapatalk |
04-25-2019, 04:41 AM | #33 |
Quarry Creeper Join Date: Apr 2011 Location: Germany
Absolutte great work on the transmission and engine! Is there a front support for the motor? |
04-25-2019, 07:03 AM | #34 |
There are mounts on the sides of the block and I am creating a bracket from the frame that also acts as a securing piece for the shock hoops that fits inside the “c” channel frame. Then you can secure with a M3 and nut similar to a real motor mount. Sent from my iPhone using Tapatalk |
04-26-2019, 03:00 AM | #35 | |
Where`s the like button when you need one? | |
05-15-2019, 09:10 PM | #36 |
Here is the latest update. Made a few more changes and basically updated the design from the transfer case forward. Sent from my iPhone using Tapatalk |
05-16-2019, 08:12 AM | #37 |
Rock Stacker Join Date: Jun 2018 Location: PNW
Impressive work! All the details are turning out great! |
05-16-2019, 08:19 AM | #38 |
05-31-2019, 02:40 PM | #39 |
Newbie Join Date: Sep 2017 Location: Montreal
I am looking at making something similar out of the guts of an SXC10 kit gearbox and was wondering exactly what you were using for shafts, since they look a tad different to the stock shafts. Really nice project BTW. |
05-31-2019, 05:02 PM | #40 | |
The bottom shaft is original but I had the gear slide turned down. The top shaft I had machined smaller. Otherwise everything is from the SCX10.2 kit trans. Sent from my iPhone using Tapatalk | |
My SCX10.2 Motor and Tranny so far... - Similar Threads | ||||
Comp Spec Front Side Tranny/Motor/Servo/Winch mount set for SCX10 2 | The Crawl Space | Chassis and Suspension | 24 | 06-22-2020 05:52 PM |
Scx10 chassis an wraith motor/tranny axle question | 07trd4x4 | Axial SCX-10 | 10 | 05-06-2012 10:18 PM |
