Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: raw builders kit transmission question
Old 03-20-2019, 01:45 AM   #1
Default raw builders kit transmission question
just got through putting my kit together ,and im just not a fan of the plastic motor mount being molded into one piece with the transmission . What do you guys think about it ? Im thinking of pulling it out and replacing it with the traditional transmission with the removal motor mount .
redbull8983 is offline   Reply With Quote
Old 03-20-2019, 06:05 AM   #2
Moderator
JatoTheRipper's Avatar
Default Re: raw builders kit transmission question
It’s a stupid, cost cutting design for sure, but you probably won’t have any issues with it.
JatoTheRipper is online now   Reply With Quote
Old 03-20-2019, 07:34 AM   #3
It's certainly thick enough. I doubt it will cause any trouble.
OSRC is offline   Reply With Quote
Old 03-20-2019, 07:45 AM   #4
There is some good and some bad.
The plastic is super rigid so there is no flex to mess with gear mesh and the screw holes that hold the transmission to the skidplate don't strip out like you are threading into warm butter.
I wouldn't go back and install an old plastic case just to have an aluminum motor plate but an aluminum case with an aluminum motor plate is a nice upgrade although not an immediate need.
svt923 is offline   Reply With Quote
Old 03-20-2019, 09:24 AM   #5
I agree with Svt.
I ran brushless 3000kv 4 pole motor on 3 s through mine with zero issues.
Heat might be an issue, but you would be hurting a motor to get enough heat to melt the plastic imo.
lonleycreeper is offline   Reply With Quote
Old 03-20-2019, 12:29 PM   #6
Money spent on that really could be spent elsewhere for a really long time and do more for your rig.
Xx Losungen xX is offline   Reply With Quote
Old 03-20-2019, 01:14 PM   #7
I’d bet that there’s not anyone out there who has had any kind of failure or issue with it. It’s fine. The plastic is strong and thick enough. You can hear/feel the grit of the reinforcement in the plastic when assembling the trans.
LSXGMC is offline   Reply With Quote
Old 03-21-2019, 06:12 AM   #8
Originally Posted by LSXGMC View Post
Iíd bet that thereís not anyone out there who has had any kind of failure or issue with it. Itís fine. The plastic is strong and thick enough. You can hear/feel the grit of the reinforcement in the plastic when assembling the trans.
I definitely felt the grit trying to put it together lol . I ended up with a socket head screw with the same thread and soome grease to cut the thread before i put the flat head one in it
Old 05-03-2019, 12:02 PM   #9
Originally Posted by hobbyjumper View Post
stock flat head screws.
I've never seen flat head screws anywhere in an Axial kit, only hex hardware, where did you buy your kit??
Old 05-03-2019, 12:40 PM   #10
I believe most people are referring to counter-sunk type screws as flathead. Drove me nuts for the longest time, but it's so commonly used, I'll just have to accept it!
TheLetterJ is offline   Reply With Quote
Old 05-03-2019, 04:37 PM   #11
Yup, I'm a potato, moving along now hehe
Old 05-03-2019, 06:52 PM   #12
Sorry, my apologies to the audience. In eastern Canada, a flat-head screwdriver is called a slot screwdriver and is designed to turn slotted screws (badly it would seem). Flat-head screws are screws with a flat top, designed to be installed in a countersunk hole, and can have any hole pattern, though we prefer Robertson, as it's the best. :-)
Funny...I had never heard the term hex until this hobby. I grew up calling them Allen heads, since you turned them with an Allen key, or less often an Allen "wrench".
Semantics lol.
I'm from Western Canada, never used the term "slotted" in 20 years on the tools. These screws I mistakenly took for my version of "flathead", I've always referred to as countersunk screws as they go inside a countersunk hole. One man's logic is another man's confusion, life is good!
Useless fact: Allen comes from the name of the patent holder for a hexagonal screw head in the early 1900s. Just like Robertson and square-head screws.
Old 05-03-2019, 10:25 PM   #13
Yeah, I always assumed Allen was a Brit side off the pond thing but it's merrcan. Now explain how panhead screws get their name, when they are the opposite of flat like a pancake.
Think more like the pan you would use to cook pancakes. Flat top, rounded sides, if you flip the screw it has the profile of a pan.
Old 05-06-2019, 02:53 PM   #14
I just built a raw kit a bit back. Im running this Holmes 13t crawlmaster on 3s. I beat the snot out of it and am not gentle. The truck is a beast for what it is. You can find it in the thread called Bea.
That said I am impressed with the new grey plastic and toughness. I run the slipper locked down, not a peep from the case and gears. I built it with red and tacky grease.
I have ordered a metal plate and alloy case for down the road, but am honestly surprised at how tough this one is vs the older dark ones.
mikemcE is offline   Reply With Quote
Old 11-08-2019, 01:28 PM   #15
I did switch out the gray trans for the aluminum hot racing one I already had. In the past it never took very much to over tighten and strip threads. Especially when it gets removed a bunch.
Yes this gray plastic is different. Pain in the ass to get screws started. It seems like a tuff case. Haven’t heard of any issues. The only reason I switched it out is because the hot racing case has a single sided slipper with a 48p spur. Not the 32p spur. It runs super silent and I haven’t striped it out yet. Same spur for 5 years or so. Almost time for a new one looking a bit worn
dirtman71 is offline   Reply With Quote
Old 11-09-2019, 07:29 PM   #16
Been running one for over a year with a Castle Slate 2850 on 3s. Beating the crap out of it. No issues
Sent from my SM-G975U using Tapatalk
wblteen is offline   Reply With Quote
Old 11-10-2019, 07:35 AM   #17
Look into using the Element Enduro tranny with overdrive.
DIRT HAWG is offline   Reply With Quote
Old 11-10-2019, 08:20 AM   #18
What mods did you have to do to put the Element Enduro tranny in your SCX10II.
Old 11-10-2019, 08:28 AM   #19
3S here too, and this kind of abuse.
I'd your not abusing your not using. Lol
raw builders kit transmission question - Similar Threads
RESTOCK Axial SCX10II Raw Builders' Kit! RPP Hobby RPP Hobby 0 02-11-2019 10:29 AM
Any battery tray options for the raw builders kit? BashNSlash Axial SCX10 II 23 01-09-2019 08:32 AM
Cherokee kit or Raw Builders Kit? Canít decide! twentyniner Axial SCX10 II 12 12-02-2018 10:14 AM
SCX10 II raw builders kit-questions Spence Axial SCX10 II 2 11-11-2018 08:34 AM
