04-07-2019, 08:12 PM | #1 |
Rock Crawler Join Date: Dec 2010 Location: tracy
| Yeti/bomber rear trailing arms
So I got the idea/inspiration on a build from a guy on ig (trail domination). He has a rig called wroncheti. His is running ar60s. But I plan on using ar44s. I just used yeti/bomber rear trailing arms and bomber rear upper links. Moved axle back maybe 7mm.. not going to leave the skid side of the mounts in board. Will move them outboard when I have some time to make brackets Sent from my Moto Z (2) using Tapatalk |
04-07-2019, 08:27 PM | #2 |
| Re: Yeti/bomber rear trailing arms
Where does that bring your wheel base?
04-07-2019, 08:48 PM | #3 |
| Re: Yeti/bomber rear trailing arms |
04-08-2019, 03:56 AM | #4 |
Rock Stacker Join Date: Dec 2018 Location: Winchester
Oh man I was just looking at my 10-2 yesterday and wondering about using TA’s. Had the chance to do any testing and stuff yet? You didn’t hit any snags by extending it with the driveshaft or anything? Sent from my iPhone using Tapatalk |
04-08-2019, 04:47 PM | #5 | |
| Re: Yeti/bomber rear trailing arms Quote:
The driveshaft doesn't seem to have any issues with that little bit more length and the pinion angle is about the same as original. Sent from my Moto Z (2) using Tapatalk | |
04-10-2019, 06:52 PM | #6 |
Ran it today for work few minutes. It runs good. No binding. I think I want to get some 100mm or 110mm shocks for the rear. And have them set up to have sag so it's still at stock ride height. Sent from my Moto Z (2) using Tapatalk |
04-14-2019, 08:19 PM | #7 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Technically it isn't trailing arms when you have the shock mounted to the axle. Moving the shock towers to the forward most position (and swapping them from left to right) on the chassis might allow you to get the shocks pretty straight up and down on the rearmost mounting hole on the trailing arm. That will save you from having to buy long shocks if travel is what you are looking for, as one of the benefits of trailing arms is more travel with shorter shocks. It will however, require you to drill new holes in the body for your body posts.
04-14-2019, 08:22 PM | #8 |
I know exactly what trailing arms are. I just have not had the chance to change everything yet. Just wanted to see how they fit mostly right now. I am going to mount the shocks on the arms. Sent from my Moto Z (2) using Tapatalk |
Yeti/bomber rear trailing arms - Similar Threads | ||||
Bomber/Yeti Trailing Arms | Blue Monkey RC | Axial RR10 Bomber | 13 | 03-16-2016 11:26 PM |
