Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Cutting foam tire inserts?
Old 05-17-2019, 08:59 PM   #1
Default Cutting foam tire inserts?
Been out of the game for a while but I am recovering from surgery and building an UMG10.
Do people still cut the tire foams or is the foam better now to the point itís not worth it?
mannysouza is offline   Reply With Quote
Old 05-17-2019, 09:06 PM   #2
Default Re: Cutting foam tire inserts?
Every stock foams really need to be replaced by crawler innovation dual stage foams.
There is just no other way
Sent from my Pixel 2 XL using Tapatalk
Jboucher is online now   Reply With Quote
Old 05-17-2019, 09:14 PM   #3
Thanks, I plan on getting better tires and wheels. I will check out those foams.
In the mean time,
If using stock foams would you recommend cutting them?
People still using the star pattern?
Old 05-17-2019, 09:22 PM   #4
I don't see it much anymore. Modern tires and compounds are so soft, that added contact patch isn't worth the drawbacks. The foams need to be hard hold the tire up and keep it from folding over.
But I'm just an idiot on the internet. If you plan on replacing them anyway, give it a shot.
Sent from my ONEPLUS A5010 using Tapatalk
poohsad is offline   Reply With Quote
Old 05-18-2019, 06:25 AM   #5
CI foams, We arenít in the 80ís any more. Star cuts went out with disco
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 05-18-2019, 08:53 AM   #6
Proline dual stage work for me. Lighter rig CI, heavier Proline.
Sent from my Moto G (5) Plus using Tapatalk
scaled is offline   Reply With Quote
Old 05-18-2019, 10:58 AM   #7
indybama's Avatar
I run CI lil novas in my pitbull rock beast tires n they do awesome. Lookin to get another set of tires n ci foams for another build soon
Sent from my SM-J327VPP using Tapatalk
indybama is offline   Reply With Quote
Cutting foam tire inserts? - Similar Threads
Tire foam inserts The Punisher Axial Yeti XL 1 08-14-2017 06:35 AM
tire foam cutting tmaxxman80 Axial SCX-10 6 02-02-2013 06:25 PM
Cutting Board Tire Inserts CronusTRD Tires and Wheels 17 08-10-2009 07:30 AM
cutting tire foam?? 1TONCHEVY Tires and Wheels 12 12-04-2008 01:31 AM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
