05-19-2019, 02:23 PM | #1 |
Newbie Join Date: Dec 2018 Location: Cleveland
| SCX10ii Honcho Suspension Issue(s)
I'm running into an issue with the Vanquish Stainless Steel Link Kit and my SCX10ii Honcho (stock axles) I recently upgraded the suspension to the Proline Pro-Spec 105mm - 110mm shocks front\rear and although the rear has no issue, I'm having an issue with the panhard link. When I attach the panhard link, it forces the entire axle to the left (if you look straight at the truck) and is the only way I can get that link to fit. / / instead of | | Is it possible to run that suspension size with the current links or do I need to find an adjustable panhard? Also, what would be a good front and rear driveshaft combination? The hot racing rear shaft works, but the front one is a bit short (and placing the stock one back in binds everything up) Sorry for all the questions |
05-19-2019, 03:13 PM | #2 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
| Re: SCX10ii Honcho Suspension Issue(s)
Need to adjust pan hard and steering link length for new ride height, it's quite normal.
05-19-2019, 04:16 PM | #3 |
Taller shocks will mean likely longer pan and drag link to keep proper geometry. Even swapping rod ends out will change things up. If using Axial ends and swapping out to Traxxas . Hang up and Drive |
05-23-2019, 11:41 PM | #4 |
Rock Stacker Join Date: Apr 2019 Location: Reno, NV
Thinking the shocks are too long for the Honcho.
05-24-2019, 06:46 AM | #5 |
I ended up going from a 3-link setup to a 4-link which fixed the issue.
05-24-2019, 09:16 PM | #6 |
No loss of articulation in the front?
SCX10ii Honcho Suspension Issue(s) - Similar Threads | ||||
Scx10II TRAIL honcho | Chilli39 | Newbie General | 20 | 01-24-2018 04:05 PM |
Steering linkage/suspension issue | Fishcharger | RC4WD Trail Finder 2 | 4 | 09-26-2017 04:24 PM |
G6 kit front suspension issue? | idaho | General Crawlers | 5 | 02-11-2014 06:27 PM |
suspension issue I think??? | fisherkip | Axial AX-10 Scorpion | 1 | 10-15-2009 01:47 PM |
