Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: First upgrades for the UMG10?
Old 06-16-2019, 12:14 PM   #1
Default First upgrades for the UMG10?
What would you upgrade first on this kit. I have a tekin brushless setup. aNY AXLE UPGRADES RECOMENDED?
Traulus is offline   Reply With Quote
Old 06-16-2019, 03:37 PM   #2
Default Re: First upgrades for the UMG10?
SSD brass knuckles and brass rear axle weights, as the wheelbase is very short and the center of gravity is high on the UMG10...
Heavy Brass Knuckles for SCX10 II / Pro44 Axle
Brass Weights for SCX10 II
I have the brass knuckles and rear axles weights that SSD makes for the Vaterra Ascender and my '72 Chevy K10 works much better with them installed.
durok is offline   Reply With Quote
Old 06-16-2019, 11:02 PM   #3
Overdrive would be my first. Made the biggest difference of the upgrades I have done.
DirtyDillo is offline   Reply With Quote
Old 06-17-2019, 11:34 AM   #4
Is this the part that you are reffering to?
https://www.amainhobbies.com/axial-a...i31530/p724416
Old 06-17-2019, 11:35 AM   #5
Got it, don't though how I will fit the reara axle weights
Old 06-18-2019, 05:00 AM   #6
That is the default gear ratio, you need 27T/8T...
https://www.amainhobbies.com/hot-rac...xt9278/p710174
Also, really smooths out the transmission...
https://www.amainhobbies.com/vanquis...s08106/p581715
celt is offline   Reply With Quote
Old 06-18-2019, 06:37 AM   #7
I already have the vanquish top shaft and vanquish transfer box. As far as the gears, stayng out of HR products as much as I can
Sent from my SM-G955F using Tapatalk
Old 06-19-2019, 09:47 PM   #8
https://supershafty.com/collections/...12998409060446
These, they are perfect for the 6 bolt pattern making them stronger. Stock gearing is 30/8. I just use one in my front diff.
First upgrades for the UMG10? - Similar Threads
TRX4 portal axles to UMG10 Traulus Axial SCX10 II 16 01-21-2020 05:59 PM
MeanTT’s UMG10 MeanTT Axial SCX10 II 22 06-25-2019 07:02 PM
Calling UMG10 owners! Oh How Original General Crawlers 10 06-18-2019 04:27 AM
UMG10 CVD help royalm Axial SCX10 II 4 04-24-2019 07:59 AM
