06-18-2019, 03:09 PM | #1 |
Newbie Join Date: Jan 2019 Location: Mankato
| SCX10 II Toe
Im just putting the builders kit together and noticed on the front axial there will be a little toe in. Is this normal on this vehicle or should there be no toe in?
06-18-2019, 04:07 PM | #2 |
| Re: SCX10 II Toe
I will have to look at mine. But I don't remember any noticeable toe in or out.
06-18-2019, 04:08 PM | #3 |
| Re: SCX10 II Toe
Yeah it does have a little of that depending on how tight you thread the rods in. I usually just adjust the rod ends until the toe is even and throw in spacer if there are threads showing.
06-18-2019, 04:41 PM | #4 |
Rock Stacker Join Date: Apr 2009 Location: PNW
| Re: SCX10 II Toe
At the speeds you'll drive an SCX10ii, there is zero need for toe-in. The only benefits are high speed stability and faster turn-out traction, neither of which apply to a slow solid axle truck. Now some toe-out will actually give you a bit more steering in very tight turns as it will mimic some Ackerman in the steering, which the AR44 axles lack. Just adjust it until you have zero toe. That's what I've always ran on RC crawlers and 1:1 Crawlers and it's recommended by most. |
06-18-2019, 04:54 PM | #5 | |
| Re: SCX10 II Toe Quote:
Nothing wrong with asking questions when something seems odd. I set my steering links to have 0 toe, and as Zane pointed out the only "good" toe is toe out as at least that get you something with it. Last edited by HumboldtEF; 06-18-2019 at 04:56 PM. | |
06-18-2019, 07:09 PM | #6 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
| Re: SCX10 II Toe |
06-18-2019, 07:59 PM | #7 |
| Re: SCX10 II Toe
Sorry Hobbyjumper I was a bit grumpy, already fixed my tranny issue with a VP topshaft.
06-19-2019, 09:46 AM | #8 |
| Re: SCX10 II Toe
So If I go backward on the links so there is threads showing do you guys recommend to take the coupling off all the way and put spacers in there or just run it with the threads showing? Also how much grease are you guys using in the axial casings, it never really says to use a drop or a glob.
06-19-2019, 09:56 AM | #9 | |
You can get by without a spacer but putting one in may prevent the rod end from twisting around since with it you can really tighten it. Grease for the axle, I coat the pinion and ring gear filling the gaps between the teeth. You dont need to go crazy but its definitely more than a drop. | |
06-19-2019, 10:50 AM | #10 | |
I run the tube fairly flat over the voids in the teeth filling the teeth with the grease, but not going above the top of the teeth. I have done this with all of my rigs and have never had a problem. | |
06-24-2019, 03:18 PM | #11 | ||
Rock Crawler Join Date: Feb 2012 Location: Michigan
Didn't need a VP shaft to keep your gear from grinding. You just had the 36t gear, AX31416, flipped around the way. Both sides have a slot for the pin, only one is right and the other is a few thousandths too deep and lets the gears hit each other. | ||
06-24-2019, 11:16 PM | #12 | |
I had that sorted, double checked anyway. Really I think the pinion set screw was likely grazing the spur gear as the sloppy stock top shaft moved in and out. It was fine for a few months which is why I was thrown off I guess. | |
06-25-2019, 08:49 AM | #13 | |
For an RC comp buggy, I agree that common truck knowledge is out the window. But on scale rigs, a lot of setup carries over. Notice how almost everyone is trying to get away from reverse Ackerman knuckles? It's because steering is worse with reverse Ackerman, your outside tire wants to turn more but the inside tire is pushing the truck straight. Adding toe-in does the same thing, whereas toe-out emulates some much-needed Ackerman. Or if you have correct Ackerman knuckles... Zero toe is perfect. | |
06-25-2019, 10:26 AM | #14 |
| Re: SCX10 II Toe I cobbled my top shaft up to eliminate the front to back movement. A couple aluminum spacers and an inner bearing race did the trick. I could see the pinion set screw hitting the spur with as much slop the shaft has.
06-25-2019, 10:30 AM | #15 | |
06-25-2019, 11:14 AM | #16 |
| Re: SCX10 II Toe |
SCX10 II Toe - Similar Threads | ||||
SCX10 Camber or Toe or something steering issue. | webbl19 | Axial SCX-10 | 10 | 05-14-2017 07:41 PM |
ax10 convert to scx10 rear axle toe | mikesed | Axial SCX-10 | 1 | 04-08-2017 05:38 PM |
Toe out ? | SouthernComfort | Axial Wraith | 10 | 02-15-2015 09:30 PM |
Toe in, Toe out, or Zero ack? | The Jackalope | General Crawlers | 19 | 03-11-2012 11:11 AM |
