underdrive gear set? Anyone making an underdrive gear set? I want to underdrive the rear on my UMG10. |
Re: underdrive gear set? Overdrive only exist right now. Underdrive would likely require a larger diameter ring gear which is limited by the case dimensions. |
Re: underdrive gear set? If I overdrive the front, will torque twist be an issue? |
Re: underdrive gear set? OD front and/or UD rear should reduce percieved TT (torque twist). |
Re: underdrive gear set? Quote:
Second, steering is noticeably improved as it almost acts as a minor dig setup where the front grabs and goes more than the rear so your truck turns tighter. |
Re: underdrive gear set? i achieved OD/UD on an scx10v2 by replacing the whole tranny. i used a toyzuki motor mount (clone i think for a scx10 v1 chassis) and married it to a china modified tcase, drilled and added a center shaft that rotates OD (front) and UD (rear) gears, the axle are all stock. This is the modded tcase... http://vlozity.net/akumu/scx10v2/akumu-scx10v2-63.png thus was how the old toyzuki style motor mount was mounted before modding the tcase, currently the tcase lays flat on the alloy tranny skid plate. http://vlozity.net/akumu/scx10v2/akumu-scx10v2-43.png my chassis is currently being updated again, i hope to drive it soon. hth! |
