Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Ae5l issues
Old 09-22-2019, 12:02 AM   #1
Default Ae5l issues
I have come across a weird issue with my ae5l esc! The other day I went on a decent hour long hike, only used 3/4ths of a 6400mah battery and after taking the rig home and plugging in the battery to the esc it wants to get stuck at full steering lock then the esc rapidly blinks and I get no response from the receiver. If I unplug it and plug it back in it usually works just fine after that. Occasionally after it sits unplugged for a few hours it will repeat the weird full lock but after a few resets it works normal. Any ideas? I’ve tried it on multiple lipos, only upgrades are a power he 20kg servo and incision driveshafts, which wouldn’t cause the issue its frustrating because it’s a new rig and has never had a full battery ran through it! And it’s basically new but I don’t have a receipt so I doubt axial would cover it under warranty or anything!
Bubba503 is offline   Reply With Quote
Old 09-22-2019, 06:05 AM   #2
Default Re: Ae5l issues
Axial RTR electronics : Ready To Replace
Grab a hobbywing 1080 and never look back. While your at it, put a Holmes Hobbie sealed can motor in it for 10x better driving feel.
Sent from my Pixel 2 XL using Tapatalk
Jboucher is offline   Reply With Quote
Old 09-22-2019, 06:59 AM   #3
Does it work without the servo plugged in?
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 09-22-2019, 09:45 AM   #4
Hang up and Drive
Does the same thing, locks up once or twice then works fine
Old 09-22-2019, 09:58 AM   #5
I think the thing that is confusing me the most is that it works fine after I unplug and plug in the battery a few times, and it only does it after it sits a while with no power
Old 09-22-2019, 02:10 PM   #6
That sounds like a leaking circuit/ heat can cause it. Temp gun ?
Hang up and Drive
Old 09-22-2019, 03:42 PM   #7
Hang up and Drive
The servo and esc have never gotten hot to the touch! Like I said it usually happens when it’s been off for an hour or more.
Old 09-22-2019, 04:06 PM   #8
Default Ae5l issues
I dumped my AE5 because the yellow signal wire was broken right at the ESC and was intermittent. A failed capacitor inside could leak down.
I’m assuming LiPo’s and mode is set the same
Hang up and Drive
Old 09-22-2019, 08:32 PM   #9
Hang up and Drive
Yep the jumpers are in the correct position. I’m wondering if the servo is drawing more voltage when first ran, causing the esc to trip the cutoff mode?
Old 09-23-2019, 04:40 AM   #10
Possibly
Hang up and Drive
Old 09-23-2019, 08:43 AM   #11
Default Ae5l issues
https://imgur.com/a/Fl3o18g managed to get it on video. Did it four times this morning then worked fine.. it’s weird it blips the throttle when it dies too
Old 09-23-2019, 09:02 AM   #12
Moderator
JatoTheRipper's Avatar
This times ten thousand!
Old 09-26-2019, 11:48 AM   #13
Hobbywing 1080 is the best bang for the buck hands down!
braytonia is offline   Reply With Quote
Ae5l issues - Similar Threads
esc issues or elec issues camogonewild Newbie General 5 03-11-2014 11:19 AM
I Might Have Issues v84x4 Kyosho Crawlers 210 08-20-2013 02:43 AM
Having issues. rebel GMC Electronics 27 11-19-2009 10:01 PM
Having some issues Wheetness Electronics 6 07-27-2009 10:30 AM
