11-03-2019, 09:01 PM | #1 |
Pebble Pounder Join Date: Aug 2019 Location: Redlands, CA
| Newb learns some things about AR44 axles, lol.
Late to the game, I know, but there’s sooo many things to learn. So the (newest ?) AR44 is a one piece design, at least it is for the UMG10. And doofy axle weights like these Yeah Racing numbers have no place to mount up. So I threw some perhaps good money after bad and ordered a fancier SSD Pro44 three piece axle because they’re mine now that they’re opened and that doesn’t fit the weights or the existing hardware. Needs a shock link and C-hub...do I have that right? Or is Pro44 a different form factor, in case I’m doing the wrong thing here again?
11-03-2019, 09:55 PM | #2 |
Rock Crawler Join Date: Mar 2017 Location: Rubicon Trail
| Re: Newb learns some things about AR44 axles, lol.
The pro44 needs the link mounts and the chubs. If you go for the vanquish link mounts, the hardware is included. You can use some stock plastic axial chubs which are $6ish. As far as I know the brass doesn’t fit the pro44s. I’d recommend SSDs weighted knuckles, or just using some lead weight in the tires, around the inner ring of the wheels. Sent from my iPhone using Tapatalk |
11-03-2019, 10:32 PM | #3 |
Awesome. Just put 60g in each front wheel like you described...seems pretty great like that—thanks.
11-03-2019, 10:59 PM | #4 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
Samix brass chubs and link mounts will fit
11-05-2019, 11:47 PM | #5 | |
| Re: Newb learns some things about AR44 axles, lol. Quote:
The money spent would likely have been better going overdrive in the front, but since I had not done it yet, I wanted to experiment with weight down low on the front axle, just to see what that would do when things get steep and low traction. Then the axles were chasing a pretty bad choice with that brass, but live and learn. The Mog maybe also seemed like it would be more-Moggy with more front weight. I’m totally open to suggestions, but for now front weighted lead in metal beadlocks feels pretty good with a torquey little HH 35t Expert. I may be done modding it for now and am pretty happy with this first build and the flexibility it lends to playing around with other shells, especially the one here with the improved approach angles. It’ll still need some quality rubber down the road, for sure. Thanks for your thoughts, all. I really appreciate and use them. | |
11-06-2019, 12:40 AM | #6 |
Quarry Creeper Join Date: Jul 2015 Location: Menifee
I just finished my scx10.2 build today and took it out for a run. I was very impressed. It was doing things much easier than my scx10 did. Only real difference was I put softer foam in the front tires. Hydrax with a double wrap of lead. And I have the 10% overdrive gears in the front. I think that really makes the difference. You could see the front tires flexing out and getting a good bite and pulling it’s way through. I thought the soft foam wouldn’t roll over too much on sidehills, and it did but they still got bite and never flipped me All I am saying is I think the overdrive gears are worth the $35. I got the ssd od gears and 6 bolt locker |
11-06-2019, 06:31 AM | #7 |
Shouldn't be a high horse when we are talking about toy trucks 90% of us here are adults playing with toys, perfect I spend more time tinkering then I do playing with the bloody things, just no time to get out. Enjoy the process man, it's half the fun!
11-06-2019, 12:33 PM | #8 |
Yes that is the fun part...the build. The setup and the changes in the setup to make it crawl better or worse. What works for some doesn’t always work for others. Mostly because we all have different driving styles
11-06-2019, 01:08 PM | #9 |
I wanna be Dave Join Date: Sep 2019 Location: US
I'm going the 4WS route, plus portals, so going to be using front axles front & rear. As the portals have 'built-in' OD capability, just by reversing the order of the portal gears, as well as a higher OD gear option, this raises an "interesting" question: Which is the better/smarter/more efficient way to go? OD via gears in the axle housing? OD via the portals? Or, at stupid as this idea might sound (even to me), a combination of both? Needless to say, I've never done 4WS before, so, I'm breaking into new territory here (as I enjoy doing). ~ More peace, love, laughter & kindness would make the world a MUCH better place |
11-07-2019, 08:55 AM | #10 | |
Panther, dude, I love how you came on-scene like a minute ago (about the time I found this site, myself) and were instantly “all-in” and immediately trying to pull off all kinds of cool shit like the one you’re talking about here. Maybe I’ll try the same. And if this thread doesn’t get much more attention per your question, let’s raise the questions again in it’s own thread. I’m getting busy for a while with work but will always be checking back. Quote:
11-07-2019, 09:12 AM | #11 | |
~ More peace, love, laughter & kindness would make the world a MUCH better place | |
Newb learns some things about AR44 axles, lol. - Similar Threads | ||||
Rc4wd portal axles for axial ar44 axles scx10 ii | soze | General Crawlers | 1 | 06-04-2019 02:12 AM |
Ar44 axles or vp axles with mounted servo | Johan_Eriksson | 1.9 Scale Rigs | 9 | 10-29-2017 01:00 PM |
Im still a newb. lol | BEELZEBOB | Newbie General | 6 | 07-23-2009 01:19 PM |
vid: lol.... kids say the darndest things | NeXt559 | Chit Chat | 7 | 01-18-2009 06:31 PM |
