11-25-2019, 09:42 AM | #1 |
Newbie Join Date: Oct 2019 Location: Somerset county
| Less flex after yeah racing desert lizard shocks?
My stock shocks were leaking and loose but they had a lot of travel. New ones seem to be stiffer (they compress most of the way) it seems like the suspension has a lot less flex. 90mm. Normal? Maybe I should invest in a higher quality shock? I am using the 1 soft spring inside that’s it. Sent from my iPhone using Tapatalk |
11-25-2019, 10:18 AM | #2 |
Pebble Pounder Join Date: Dec 2017 Location: Pinehurst
| Re: Less flex after yeah racing desert lizard shocks?
I like 100mm kings Sent from my SM-G930V using Tapatalk |
11-25-2019, 11:01 AM | #3 | |
| Re: Less flex after yeah racing desert lizard shocks? Quote:
Edit, iirc those are internal spring shocks, I'm not a fan of this setup due to the mess you have to deal with to swap springs. This also created a 100% droop setup, which I'm also not a fan of, like to have some up and down travel when the truck is sitting at ride height. Also less travel is sometimes better crawling, IME I don't like tons of flex and suspension travel, ymmv. Last edited by Natedog; 11-25-2019 at 11:04 AM. | |
11-25-2019, 12:11 PM | #4 |
Well said Natedog.
11-25-2019, 12:18 PM | #5 |
Newbie Join Date: Sep 2019 Location: Paradise
Less flex can be better for crawling. I have the Desert Lizard shocks on my Ascender and like them. I have them in the "mostly" droop setup. I just had to go from the soft to medium short springs supporting the truck. I have the soft springs in the rebound position. My truck did great with the soft setup until I modified the battery tray to go to a comp, the extra sprung weight was completely bottoming out the softs.
11-25-2019, 09:03 PM | #6 | |
This is because the displacement of the shock shaft increases the pressure inside the body of the shock. Also I only fill mine like 50-75% of oil. Sent from my SM-N950U using Tapatalk Last edited by Voodoobrew; 11-25-2019 at 09:06 PM. | |
Less flex after yeah racing desert lizard shocks? - Similar Threads | ||||
Desert Lizard shocks droop setup | bbrigg | General Crawlers | 8 | 02-06-2022 06:24 PM |
Desert Lizard Shocks | Ranger1996 | Axial SCX10 II | 8 | 11-06-2019 01:25 AM |
help with yeah racing desert lizard shocks | Spence | General Scale Talk | 3 | 08-10-2019 11:00 PM |
Desert Lizard Shocks for SCX10 ii | dubdeuce386 | Newbie General | 25 | 06-26-2019 01:14 PM |
yeah racing shocks | non ya | Axial AX-10 Scorpion | 10 | 11-28-2008 06:58 AM |
