01-23-2020, 05:07 AM | #1 |
RCC Addict Join Date: Oct 2014 Location: UK
| New SSD Trail King Scale Transmission Set |
01-23-2020, 07:32 AM | #2 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
| Re: New SSD Trail King Scale Transmission Set
Nice, you guys are killing it. This is the cheapest option for this type of tranny that fits the point system of our local scale series. |
01-23-2020, 08:00 AM | #3 |
Quarry Creeper Join Date: Feb 2009 Location: Houston
When are the Servo mounts & battery plates going to be available?
01-23-2020, 10:38 AM | #4 |
| Re: New SSD Trail King Scale Transmission Set |
01-23-2020, 11:40 PM | #5 |
I wanna be Dave Join Date: Sep 2019 Location: US
This is probably going to sound like a 'dumb' quotation, but, so be it. Is this the same transmission that comes in the TK kit, or is it different in any way(s)? If it is different, what are the differences/changes? ~ More peace, love, laughter & kindness would make the world a MUCH better place |
01-24-2020, 12:24 PM | #6 |
How much reduction is possible with the Spur pinion? How much overall reduction in the transmission itself? I am running 14/87 and a Axial 3 gear with 10 II axles in my big Bronco and would love to drop a scale transmission in, but the brushed motors don't like much taller gearing than I have currently due to 5.4" Tsl Boggers. My current transmission ratio is 16:1 or so. Last edited by lonleycreeper; 06-11-2020 at 09:26 AM. |
01-24-2020, 12:51 PM | #7 | |
| Re: New SSD Trail King Scale Transmission Set Quote:
The aluminum transmission is lower with a stock ratio of 14.33:1 using the stock 14T pinion. There is room for going down a few teeth on this one as well. | |
01-26-2020, 04:07 AM | #8 |
| Re: New SSD Trail King Scale Transmission Set This is the Trail King transmission with no changes to it.
06-10-2020, 03:39 PM | #9 | |
RCC Addict Join Date: Jun 2008 Location: Mudville
Putting in an Axe 550 3300kv system, and it has a 5mm shaft and the pinion that comes with the Axe system is a 12t but the wrong pitch. I got no mesh love between them, so need to source a pinion that will fit on the 5mm shaft from the motor, and mesh with the stock gear in the tranny. | |
06-11-2020, 06:14 AM | #10 | |
https://www.amainhobbies.com/robinso...54470?v=218930 Hot Racing makes smaller 48P pinions for a 5mm shaft but I'm not sure if that thick collar at the base of the gear will interfere with the mesh on the SSD trans. https://www.asaphobbies.com/hot-raci...0aAsAuEALw_wcB | |
06-11-2020, 07:54 AM | #11 | |
that's what I discovered. Ordered a 17,18,19t RR pinion and a 14 and 16t from Hot Racing. Nice to have some options. | |
06-20-2020, 10:58 PM | #12 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
Just to confirm, this will not work with a centered front SSD Diamond housing? I just put them in my SCX |
06-21-2020, 09:18 AM | #13 |
06-21-2020, 05:12 PM | #14 |
Rock Crawler Join Date: Mar 2008 Location: Plainfield
How is the slop on this tranny at the outputs? Lou |
06-21-2020, 11:26 PM | #15 |
| Re: New SSD Trail King Scale Transmission Set Nill to Zero. I move the tire, and I barely rotate it and the tranny is moving. if it was on the table. less than 1/4 inch tire travel. not 1/4 tire roll. lol 1/4 of an inch movement, and that is Max and the tranny is moving. It's a rather tight driveline, from tranny gear all the way through to wheels. Last edited by Timmahh; 06-21-2020 at 11:33 PM. |
New SSD Trail King Scale Transmission Set - Similar Threads | ||||
New SSD Trail King Side Sliders Set | SSD | Axial SCX10 II | 0 | 01-23-2020 04:37 AM |
SSD Trail King - Pro Scale Chassis - Price Drop! | RPP Hobby | RPP Hobby | 0 | 10-07-2019 10:30 AM |
NEW SSD Trail King - Pro Scale Chassis - IN STOCK! | RPP Hobby | RPP Hobby | 0 | 07-12-2019 12:31 PM |
Yet another sneak peak of the NEW SSD Trail King Pro Scale Chassis! | RPP Hobby | RPP Hobby | 2 | 05-24-2019 04:08 PM |
Coming Soon - NEW SSD Trail King - Pro Scale Chassis | RPP Hobby | RPP Hobby | 2 | 05-19-2019 05:50 AM |
