03-20-2020, 08:25 PM | #1 |
Newbie Join Date: Feb 2020 Location: Covelo, CA
| Transmission blew up
So I blew up my stock transmission today in one of my trucks. So I ran down to RPP and picked up a Hot Racing complete transmission ran home and slapped it in. Not impressed. My other Scx10ii with stock transmission really outperforms it. And it is super noisy! What is a good aftermarket transmission that isn’t super expensive? Or is it better to rebuild my old stock one? I have not been around many rscx10ii rigs that have a lot of major aftermarket parts. Besides shocks and servos and basic stuff. What do you guys think?
03-20-2020, 09:14 PM | #2 | |
Newbie Join Date: Dec 2019 Location: US
| Re: Transmission blew up Quote:
been using it in my MT scx10ii and its holding up to me bashing it and racing it everywhere. Sent from my SM-N910T using Tapatalk | |
03-20-2020, 09:36 PM | #3 |
Quarry Creeper Join Date: Jun 2013 Location: San Francisco
I rebuilt all my SCX transmissions with helical cut gears. XtraSpeed & Team Raffee make sets for both the Kit & RTR transmissions. I’ve got tons of run time and 2 Axialfests on all my SCXs, and they’re smooth & quiet. The helical gears allow for a larger contact area between gear teeth, which makes for a stronger gear mesh. They’re all metal gears, so the first few runs will be a little noisy, but once everything’s run in they quiet down. I still run a plastic spur gear on all the transmissions. It’s an intentional “weak link” to save the rest of the transmission if something binds up. It’s also easier to access & replace vs an internal gear. These are what I used: https://www.asiatees.com/display?Axi...d=114580&pid=1 https://www.rcmart.com/xtra-speed-45...30081-00073208 |
03-20-2020, 10:21 PM | #4 | |
03-20-2020, 10:54 PM | #5 |
I have had great sucess with rpp gears in my transmissions...
03-21-2020, 06:30 AM | #6 |
What “blew up “? If you had plastic gears, update. I’ve run 3 or 4 different 3gear trans, all about same ..... My VP looks the best, but all are geared the same and work the same Hang up and Drive |
03-21-2020, 09:33 AM | #7 |
| Re: Transmission blew up Sorry should have elaborated. The plastic gears stripped out to where they almost smooth. What caused it was my 4 year old was crawling around and he nosed up to a rock that he could not get up and instead of readjusting he hammered it.
03-21-2020, 09:53 AM | #8 | |
Get the replacement metal gears, you should be set. Even axial metal gears will be fine. Hang up and Drive | |
Transmission blew up - Similar Threads | ||||
Blew my driveshaft | MeanTT | Axial Yeti | 4 | 12-28-2014 09:51 PM |
Blew up the yeti already | m1009cucv | Axial Yeti | 2 | 09-22-2014 11:29 AM |
I think my ESC just blew | johnnyh66 | Losi Micro-Rock Crawler | 13 | 12-17-2010 08:25 PM |
I Think I blew it | BJoe | Electronics | 5 | 08-12-2007 06:15 PM |
