03-28-2020, 08:37 PM | #1 |
Newbie Join Date: Aug 2019 Location: North Carolina
| Scx10.2 Front axle U joint
I've noticed the stock dogbones seem to bind slightly when turning in one direction. I'm also in search of more steering angle like most people are. I want to switch to u joint axles on the front. I know axial makes a set, so does vanquish and ssd. I'm sure there are more to add. I'm just curious as to which one's are the most reputable for durability. Even the vanquish ones are only about 10 dollars more than the boom racing ones, so price seems to be almost irrelevant. I appreciate any input and owner experience
03-28-2020, 09:02 PM | #2 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
| Re: Scx10.2 Front axle U joint
Do you have universals or dog bone? I would stick with stock until theyre broke. You can do a little clearance work to get more out of them as well.
03-29-2020, 03:04 PM | #3 |
I have dog bones on the front
03-29-2020, 03:37 PM | #4 |
Okay, dogbones are very strong but as you have found are limited and bind (or chatter easily). I would suggest upgrading to a set of Axial or SSD universals. Those alone will give you the steering you are looking for and still very strong. |
03-29-2020, 04:13 PM | #5 |
Pebble Pounder Join Date: Jun 2018 Location: New Zealand
I just swapped the dogbones for universals on my sons truck. Wayyy better |
03-29-2020, 04:32 PM | #6 |
Welcome to the site! I moved this to the SCX10 II section. With universals you should be able to get around 45 degrees of steering. Axial's universals are fine. I've never had a problem with them, but I don't throw stupid power into my scalers. I didn't even realize some SCX10 II's came with dog bones. |
03-29-2020, 04:34 PM | #7 |
| Re: Scx10.2 Front axle U joint |
03-29-2020, 06:09 PM | #8 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
04-05-2020, 10:10 AM | #9 |
Quarry Creeper Join Date: Dec 2012 Location: okc
And the Wraith 1.9
Scx10.2 Front axle U joint - Similar Threads | ||||
Yati Jr Joint Axle Keeps Popping Out | the.ronin | Axial Yeti | 5 | 05-04-2020 11:51 AM |
double joint front driveshaft? | tpliquid | Tamiya XC/CC01 | 7 | 03-17-2017 09:32 AM |
U-joint falling off of axle housing | crawlerpat | Losi Mini-Rock Crawler | 0 | 05-26-2013 03:05 PM |
Narrowing front Wraith Axle for front of scx10 | rusty577 | Axial SCX-10 | 12 | 02-02-2013 10:30 PM |
