Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Axial scx10 ii Steering horn
Old 05-23-2020, 04:33 PM   #1
Default Axial scx10 ii Steering horn
I have just finished building my axial scx10 ii builders kit and installed a savox 1210sg Steering servo. I find though that the spindle is too long and the servo horn catches the damper brace?
Should I lift the horn slightly?
I am having to use the plastic stock horn as well, as the aluminium one I purchased won’t even give enough room to install the panhard.
RCMattXC is offline   Reply With Quote
Old 05-23-2020, 05:18 PM   #2
Default Re: Axial scx10 ii Steering horn
Need to use a couple spacers between the servo mount and the servo itself. I've found that two 1mm spacers in the front only works well. Should be able something together with extras in the RBK.
Xx Losungen xX is offline   Reply With Quote
Old 05-23-2020, 09:44 PM   #3
I ended up shaving a little bit of on the end of my vanquish aluminum servo horn to clear.
Verboten77 is offline   Reply With Quote
Old 05-24-2020, 10:59 AM   #4
Perfect. Used some of the spacers. Works a treat, thank you.
Axial scx10 ii Steering horn - Similar Threads
Axial SCX10 ll, SCX10, Gmade Sawback 4LS, Vaterra Ascender K5 From Malaysia. RCWin Videos! 2 12-01-2016 09:23 AM
Rc4wd trailfinder 2 axial scx10 hilux scx10 rubicon jeep TAFF1969 Scale Videos! 0 03-08-2016 08:11 AM
