Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Shocks for 2.2 conversion
Old 06-07-2020, 06:47 AM   #1
Default Shocks for 2.2 conversion
I am looking to put some 2.2 on my scx10 ii, but wondered what shocks/dampers to use? Currently have the stock Traxxas gts installed, but wondered if the long Traxxas ones will work?
RCMattXC is offline   Reply With Quote
Old 06-07-2020, 11:18 AM   #2
Default Re: Shocks for 2.2 conversion
2.2's on the 10II take a lot of work. The tires will rub the frame and links up front. the sliders need to be modified to clear the tires, and the wheel offset needs to be pushed out. Longer shocks make things worse by changing the geometry and shortening the wheelbase. Longer shocks also raise the center of gravity as do the taller tires.
It is possible and I did it myself, with my Bronco. Ultimate Adventuring Bronco
After driving her for over a year now I can say she works well, the hard body doesn't help with stability, but she runs very realistically. I am currently running rc4wd "superlift" 100mm shocks up front and 90mm out back.
lonleycreeper is offline   Reply With Quote
Shocks for 2.2 conversion - Similar Threads
Link Conversion, What Shocks??? Nick1975 RC4WD Trail Finder 2 10 02-10-2016 04:55 PM
Mud Truck Conversion Plates - what shocks? MeanTT Axial SCX-10 10 10-07-2015 09:20 AM
WK Crawler Conversion - 5 Step/HPI Conversion Hybrid birdie HPI Wheely King 12 10-29-2007 12:22 AM
