06-21-2020, 09:38 AM | #1 |
Rock Stacker Join Date: Sep 2017 Location: Germany
| SCX10 maximum spur size 56 teeth/32p is standard spur size on the SCX10. In my case I'm thinking about changing to an Vanquish Incision Motor Mount w/Gear Guard #VPS02210. What is the tallest spur possible? Does the Incision part allow taller spur gears? Thank you! |
06-25-2020, 10:58 AM | #2 |
Newbie Join Date: Jul 2019 Location: Marysville
| Re: SCX10 maximum spur size
Dont know the answer exactly but i can tell you in my search for scx10 OG transmission I found a 60t METAL spur gear ($30?) and a 64t plastic axial (or traxxas cant remember) spur gear. I bought the 64t as it was only $7. Did not want a metal spur gear and cost is insane at 30 bucks. I went to install the 64t spur gear and it does not fit as it interferes with my MIP driveshaft connection on the transmission outputs. The 64 is too large. I think the 60t would work but again, dont want metal. If you are using another brand driveshaft with smaller diameter end maybe it would fit. Also, not sure if it the if either would work with the stock or upgraded cover as i removed mine. Not sure why it is even needed esp if you are covering it with a lexan body. Last edited by MikeDean; 06-25-2020 at 11:05 AM. |
SCX10 maximum spur size - Similar Threads | ||||
SCX10 32p Steel Spur Gear Size | Vengeance | Axial SCX-10 | 2 | 02-05-2018 05:26 PM |
Spur size | dpcardoza | Axial Wraith | 3 | 04-05-2017 05:33 PM |
Bomber Maximum Motor size? | Lanky | Axial RR10 Bomber | 4 | 10-26-2016 09:51 AM |
What motor KV and spur gear size for AX2 equipped SCX10 | e32lover | Axial SCX-10 | 6 | 09-27-2015 04:58 AM |
2.2 class maximum tire size..... | Pappy | WRCCA Rules | 8 | 12-20-2010 08:45 PM |
