Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: SCX10.2 AR44 Axle issues
Old 07-28-2020, 09:40 AM   #1
Default SCX10.2 AR44 Axle issues
Ive had my XJ kit since it was released or shortly after.
Recently the Chubs on the front axle are rotating. Ive tightened the screw, switched to STRC Alum C hubs. Still happening. Looking on here, appears to be a common problem. Which may explain why they are now 1 piece housings?
I have a backup housing but really don't want this happening again...
So I started Looking at the SSD Pro 44 axle. I have everything ready to order from Amain (need some maintenance parts as well). But before I do. Are the SSD axles going to run into the same issue?
Is there another Option I should look into? I was also going to run the Off set front axle. Anyone else run this? Have any issues?
If not, the SSD C hubs are back ordered...I was going to run the Stock Axial C hubs and knuckles until I could snag a pair of the SSD variants if my option is limited to the spline outer style axle tubes.
Second question. Is anyone running the Pro Diamond Axle from SSD? I was looking into that for the UMG10 to make it look a little more "scale". Maybe add the portal kits later? Thoughts?
Thanks
1fox2go is offline   Reply With Quote
Old 07-28-2020, 10:26 AM   #2
Default Re: SCX10.2 AR44 Axle issues
Ok I think I found a second option with the Pro44
Get the Pro 44 center Section SSD00225
Add the off set Trail King Tubes SSD00366
SSD Knuckles SSD00144
SSD C Hubs SSD00292
Off Set Axles SSD00313
This will eliminate the Spline outer section.
Anyone running this type of setup?
Old 07-28-2020, 10:43 AM   #3
I built my SCX10II with the SSD axles complete. Iíve got OD gears, BrasS knuckles, and a 2200 revolver on 3s. Zero issues and Bea gets beaten and flogged regularly
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 07-28-2020, 11:23 AM   #4
Yea I think I am going with the rear Pro44 and get the Front Pro 44 with the aluminum tubes that have the built in link mounts in the offset.
This gets rid of those dumb splines on the outer tubes
SCX10.2 AR44 Axle issues - Similar Threads
AR44 axle ?'s TK421 Axial SCX10 II 6 06-03-2020 12:07 PM
SCX10 axle accessories on AR44 Munchagepeople Axial SCX10 II 2 11-22-2019 07:05 AM
Any issues with the ar44 single piece axles c-hub? dirtman71 Axial SCX10 II 3 10-06-2019 01:47 PM
IN STOCK - Axial Racing​ AR44 Complete SCX10 II Axle Kit. RPP Hobby RPP Hobby 0 04-05-2018 04:33 PM
Coming Soon - RC4WD​ Teraflex Aluminum Axle Housing Set for Axial AR44 SCX10 II! RPP Hobby RPP Hobby 0 02-02-2018 02:11 PM
