Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: RC4wd leaf spring conversion
Old 07-30-2020, 01:48 AM   #1
Default RC4wd leaf spring conversion
I want to to a rear leaf spring scx10ii build. My question is can you use links on the RC4wd conversion kit? I just want to do rear leafs not fronts. Is there a better way using the stock chassis? I did a search and surprisingly did not find anything. Thanks
HKSkook is offline   Reply With Quote
Old 07-30-2020, 02:10 PM   #2
Default Re: RC4wd leaf spring conversion
It may limit articulation if you don't get your geometry correct. Adding a link or two to prevent axle-wrap might be prudent if you do it in a way it doesn't cause any binding.
Crunch is offline   Reply With Quote
Old 07-30-2020, 07:24 PM   #3
I dont want leafs up front at all Just links.
Old 07-31-2020, 11:34 AM   #4
I'd say if you're reusing the center frame brace and the left front shock hoop (panhard bar mount) and it all mounts in the same relative locations you're GTG.
Sorry for any confusion with my first answer, I believe I read too far into the question.
RC4wd leaf spring conversion - Similar Threads
RC4WD Leaf Spring Conversion for Axial SCX10 TheManOfMiracles General Crawlers 5 02-18-2020 01:56 PM
leaf spring conversion Crawl-N-Clod Vaterra Ascender 3 01-12-2019 12:55 PM
