Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Q: Axial Trans - AX10 to SCX2
Old 08-02-2020, 11:15 AM   #1
RCO
Default Q: Axial Trans - AX10 to SCX2
Want to change the transmission in my raw builders kit, to get everything under the Hilux cab.
I allready have the Bowhouse HD BatTray installed and the flipkit as well.
It should work when i order the Axial 31439, right?
Thanks for helping!
RCO is offline   Reply With Quote
Old 08-02-2020, 11:25 AM   #2
Default Re: Q: Axial Trans - AX10 to SCX2
I'd buy parts from toyzuki forward motor mount and 2.5 t-case.. I just did this and worth every penny.
1st pic is what I originally had in my scx10ii c1.
2nd pic is what I swapped too.
Toyzuki forward motor mount and 2.5 t-case.
3rd pic internals of t-case
Sent from my SM-A505U1 using Tapatalk
tapped-out is offline   Reply With Quote
Old 08-02-2020, 11:41 AM   #3
Raw builders kit already has that transmission, it's just silver.
Xx Losungen xX is offline   Reply With Quote
Old 08-02-2020, 11:45 AM   #4
RCO
Nice setup and thanks for replying...
But i don’t wanna change the whole trans and more. Just flip.
The question is still open..
Old 08-02-2020, 11:46 AM   #5
Here's your transmission correct?
The scx10 ii transmission I showed is different then your I knew that.
Your stock builder kit transmission isn't the toyzuki parts I swapped to... the toyzuki motor mount Is silver but isn't the scx10ii transmission.
Old 08-02-2020, 11:47 AM   #6
No problem good luck.
Old 08-02-2020, 11:49 AM   #7
RCO
You’re right... my fault!
I meant the transmission from the kit version i wanna swap to.
edit:// this one
http://www.axialracing.com/products/ax31439
Old 08-02-2020, 12:12 PM   #8
edit:// this one
Nah, my bad, you are correct I read your title like a complete potato, sorry for the confusion.
Old 08-02-2020, 12:21 PM   #9
So IMO because I had the transmission I think you want to buy.. in fact I modified the transmission to have overdrive worked well..
But was to high geared for me...
So I reluctantly swapped over to the toyzuki parts. After doing so I feel it was worth every penny.
Link to modified transmission.
Thought I had a bright idea.. for over drive.
Old 08-02-2020, 02:20 PM   #10
RCO
Thanks tapped-out! Nice work on the transmission.
So the SCX2 transmission is higher geared from what i read...
This means i have to replace my 16t motor with a higher turn motor to get the „right“ speed?
Old 08-02-2020, 02:35 PM   #11
Not necessarily, might be able to run 60t spur gear and 9t pinion I didn't try this gearing with this transmission (Not sure you'll find a 60t spur).
I ran a Holmes Hobbies 16t crawlmaster motor it was faster than I wanted it to be.
Motor never heated up nor did I feel any motor stall, if this was a trail rig probably be fine.
I was building my rig as a C1 scale competition truck.
So this is why I felt gearing was to high or to fast.
I'm not a gearing guru and I never calculated gear ratio
I just seen what others in our local comp GTG'S were running in their c1 comp trucks and swapped to what works well.
Old 08-02-2020, 02:44 PM   #12
RCO
You helped me a lot...appreciate!
So i give it a try, order the transmission and see how’s it feels with the 16t.
But i think i’ll end up with a HH TorqueMaster 30 or 55t on 3S.
And the 16t goes on 2S in my winter/slow build project.
