09-06-2020, 06:28 AM | #1 |
Rock Stacker Join Date: Jan 2016 Location: watertown
| My scx10ii build
Just a scx10ii builders kit I bought already built. I added... Hobbywing 1080 esc Homes hobbies trailmaster 550 21t RC4WD deep dish 1.9 wheels RC4WD Duratrac wrangler tires Crawler innovation dual stage foams Scx10 jeep wrangler unlimited body that I'm currently working on. Sent from my Pixel 4 XL using Tapatalk |
09-06-2020, 07:13 AM | #2 |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
| Re: My scx10ii build
Nice! How did the servo horn, panhard mount and rod end all fit together? Good clearance? Sent from my SM-G930F using Tapatalk |
09-06-2020, 07:30 AM | #3 | |
| Re: My scx10ii build Quote:
Sent from my Pixel 4 XL using Tapatalk | |
09-06-2020, 07:42 AM | #4 |
I think the tires I got on it are to big the. Got alot of rub on the front fenders. Anyone have any suggestions on a good tire size for this body? I may also try limiting the flex or widening it a bit to see if that helps. I like the look of the big tires on it myself. Sent from my Pixel 4 XL using Tapatalk |
09-06-2020, 10:47 AM | #5 |
A couple options... Lift the body if possible. limit suspension travel. Or go to smaller tires. More extreme would be to modify the body and raise the fenders, though I am not sure that is possible with this body. Deal with the rubbing... I find rubbing to be extremely annoying, but I know others that let tires rub everything. My first choice personally would be to limit the suspension flex. It is a simple process of removing the shock, removing the bottom link off the shaft, and installing a length of fuel tubing over the shaft at the desired length to limit the compression. Last edited by lonleycreeper; 09-06-2020 at 10:49 AM. |
09-06-2020, 10:56 AM | #6 | |
My scx10ii build - Similar Threads | ||||
Levi's scx10ii build | Levi | Axial SCX10 II | 44 | 07-13-2021 09:06 PM |
scx10ii build, almost done finally | LJ802 | 1.9 Scale Rigs | 2 | 08-30-2020 07:25 PM |
Scx10ii new build need help with links | CrawlinJ | 1.9 Scale Rigs | 1 | 03-15-2020 07:09 AM |
My first build, SCX10II RTR JK | Unclelee | Axial SCX10 II | 8 | 05-06-2018 11:01 PM |
Allanon1965's SCX10ii build | allanon1965 | Axial SCX10 II | 70 | 10-16-2017 01:10 PM |
