11-23-2020, 11:36 AM | #1 |
Pebble Pounder Join Date: Apr 2008 Location: Marion
| 12 inch links
Does axial offer The rear links to make my scx10 II A 12 inch wheelbase. I have the kit version , so I would like to have the same Looking rear links That came with it . I got a New Bright 2021 Bronco, it is 12 inch wheelbase
11-23-2020, 12:40 PM | #2 |
Rock Stacker Join Date: Sep 2017 Location: Germany
| Re: 12 inch links
The raw builders kit included all parts, a 12.0" (11.4"; 12.3") wheelbase needed. So the lenghts are know. Why do you not look for somebody to turn them for you from the material you want to have weightwise? Gesendet von meinem SM-G955F mit Tapatalk |
11-23-2020, 12:47 PM | #3 |
RCC Addict Join Date: Aug 2020 Location: Jacksonville
| Re: 12 inch links
I’d just center up the body as best as possible on the 12.3, it is so close once you split the difference it would probably not be noticeable, we are talking an 1/8”” on either end, and longer is better than too short. Post up a photo of it sitting on the current wb.
11-23-2020, 03:08 PM | #4 |
| Re: 12 inch links
I would post pics but i have no idea how. . IBe just gotten back in to crawling , after several years . I used to post pics , but everything has changed lol. i still have all my older stuff . Which all Still work great. I just want some new updated rigs.
11-23-2020, 06:59 PM | #5 | |
| Re: 12 inch links Quote:
I use imgur now... The 10II is a fantastic little rig, the steering is what makes it imo. As said the Raw builders kit cam with everything needed to do a 12"wb... The 10II Honcho rtr did as well... So a Kit should have the prper links... | |
11-24-2020, 12:54 PM | #6 |
| Re: 12 inch links
Thanks Lonley, mine was the kit that had the Cherokee body with it and 2 speed trans. Mine only came with the 12.5 links. Thanks for The replys . Glad to be back
11-26-2020, 10:36 AM | #7 |
Built, not bought Join Date: Oct 2004 Location: Gresham
| Re: 12 inch links
Did you figure out your links? I should have some from the builders kit since I went with the 11.4 wb. You will need your rod ends though.
11-26-2020, 09:47 PM | #8 |
Rock Stacker Join Date: Jul 2019 Location: Bullard, TX
| Re: 12 inch links
I'm using Husky Links I found on eBay. Really nice parts. Here is the link to the 11.4wb that I'm using. You should be able to find a 12wb https://www.ebay.com/itm/Husky-Link-....m46890.l49292 Sent from my moto g(7) power using Tapatalk |
11-27-2020, 06:52 PM | #9 |
| Re: 12 inch links
62Pyro. i havent gotten anything yet, is your links 12" if so PM me, and thanks Screwfly for the link
11-28-2020, 06:44 AM | #10 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
| Re: 12 inch links
I just mounted a 2021 Bronco, on a HPI Venture chassis, but the wheelbase came out to 11.75" not 12". Now that I have the wheelbase set and body mounted I'm going to make my own links out of 3/16" steel rod threaded 10-24 with Revo ends. Last edited by R2j; 11-28-2020 at 06:49 AM. |
11-29-2020, 05:37 PM | #11 |
Newbie Join Date: May 2020 Location: Lexington
| Re: 12 inch links
That looks great. Just bought another SCX10 ii RBK for a new build.
12-02-2020, 09:36 AM | #12 |
Pebble Pounder Join Date: Dec 2017 Location: Pinehurst
| Re: 12 inch links
Pronoob on YouTube has a video about installing on axial chassis. I put mine on a TRX-4 SPORT with little issues Sent from my SM-G970U using Tapatalk |
12 inch links - Similar Threads | ||||
2 inch shackle on 4 inch lift | humve | 1:1 Full Size Vehicles | 17 | 04-10-2016 07:18 PM |
1 inch vs 1.25 inch wheel | mud digger | Tires and Wheels | 4 | 02-01-2012 08:00 PM |
