02-11-2021, 05:19 AM | #101 |
RCC Addict Join Date: Aug 2020 Location: Jacksonville
| Re: SLN’s Axial Experience
There are a whole mess of them though. Why wouldn’t you upgrade to aluminum ones while you are at it? I Googled sCX10 ii hex and saw more than I could shake a stick at. Here’s some Samix https://www.hobbytown.com/samix-scx1...CABEgINV_D_BwE Sent from my iPad using Tapatalk |
02-11-2021, 01:16 PM | #102 | |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| SLN’s Axial Experience Quote:
Because those still use a pin/grub screw. The whole point is to eliminate that and just go to 1 screw all the way through. They did come with the set screw, just not the kind that goes all the way through like the ones I linked. _________________ SCX10 ii Last edited by ScaleLifeNewbie; 02-11-2021 at 01:27 PM. | |
02-11-2021, 01:47 PM | #103 | |
| Re: SLN’s Axial Experience Quote:
Meh just tighten the screw, add a little loc-tite if you are worried about it. That's not something I'd overthink because my wheel came off once. Add it to your periodic check just like the axle pins. | |
02-11-2021, 02:19 PM | #104 | |
Yeah, I unfortunately don’t have any hex pins on hand that fit, so I’d have to order some, and I figured why not do it since I’m already ordering pins. Plus, Amain is out of stock on the pins. _________________ SCX10 ii | |
02-11-2021, 02:36 PM | #105 | |
Cut a piece of a wire coat hanger to get you by until the part shows up Try RPP. Amazon has them too, like a whole pile for $8 or something like that last time I checked. | |
02-11-2021, 02:42 PM | #106 |
RCC Addict Join Date: Mar 2019 Location: Hemet
I’ve even cut a heavy duty body clip to the right size and used it in a pinch.. that led to a permanent repair Sent from my iPhone using Tapatalk |
02-11-2021, 02:54 PM | #107 | ||
I’ve done that for a transmission pin. Now Im glad I kept all those big cotter pins and body clips. Lol Quote:
I’m going to order these. I’m pretty confident they will work since they seem to be the exact same thing. And if it doesn’t work for some reason, it’s only $10 so I’ll take that chance. https://www.amainhobbies.com/axial-1...32018/p1049135 _________________ SCX10 ii | ||
02-11-2021, 03:11 PM | #108 |
Oh yeah, also found that the local ACE has a huge array of 4-40 size screws/nuts/bolts for cheap, so I’ll be buying from there since it’s super cheap and fairly close. _________________ SCX10 ii |
02-14-2021, 08:19 PM | #109 |
Got some brass Also got my wiring all tidy. Weird ESC mounting location? Yes. Practical? Yes. I did have to leave some slack in that wire to be able to pop the receiver box lid off without messing with wires. So, not the cleanest, but it works. Oh yeah, metal shock towers are on the short list lol. _________________ SCX10 ii |
02-14-2021, 08:55 PM | #110 |
The grub screw I stole off the printer to put in the hex practically sheared right off. I went to unscrew it and it just fell apart lol. Got the new Losi ones in and no problems for about an hour run. _________________ SCX10 ii TRX4 |
02-14-2021, 10:09 PM | #111 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
Hey bud- Fwiw I wouldn't go with metal/ aluminum body posts/ shock towers. They can bend pretty easily and unlike plastic, you can't just bend 'em back. I've used them before and almost all of 'em have gotten tweaked during a crash or hard flop. I really think you'd be better off replacing with the same plastic ones as needed. Sucks to spend money on aluminum parts that wind up bent up after one hard roll. Also you can pretty easily fab a brace out of metal or plastic to strengthen them. Just go thru the existing mounting holes further down the posts. Up to you. Keep up the good work.
02-14-2021, 10:37 PM | #112 | |
Funny, I was just thinking about fabbing up a brace or two for them. Thanks man, I didn’t even think about that _________________ SCX10 ii TRX4 | |
02-15-2021, 03:37 AM | #113 |
Quarry Creeper Join Date: Jun 2018 Location: Blaine
I had the issues of the shock towers spreading on an scx10 I'm building for my dad. I bought an 10 pack of generic 60mm aluminum link rods off amazon, screwed them in between the top of the shock towers with some extra shock mounting screws. Holds everything straight and tight where it should be, with enough flex in the towers and stock rear posts, it "shouldn't" break after a hard roll. Sent from my LM-V600 using Tapatalk Last edited by smc-93; 02-15-2021 at 03:45 AM. |
02-15-2021, 06:14 AM | #114 | |
Just don't forget if you are making braces to keep it light. Don't want to add unsprung weight up that high if you don't need to. Honestly I don't really get the shock tower thing, they don't move that much. Panhard bracket would need to be beefy but the shock towers should be fine. I would assume if they are 'spreading' there is a conflict there - at rest my shocks are loose. | |
02-15-2021, 07:22 AM | #115 | |
Sent from my LM-V600 using Tapatalk | |
02-15-2021, 10:29 AM | #116 | |
Sounds like maybe an issue with shock length, if they were bottoming out during compression then the movement would transfer to the next 'moveable' part i.e. the mounting point (tower) | |
02-15-2021, 11:55 AM | #117 | |
Sent from my LM-V600 using Tapatalk Last edited by smc-93; 02-15-2021 at 01:33 PM. | |
02-16-2021, 06:02 PM | #118 |
So, I tried to do something, and it almost worked. After fitting the other Trailwalker body to this chassis, I wanted to get it super low-kinda like an LCG build, but just the looks. I’ve always liked really low slug bodies with just enough wheel clearance. I got it as low as possible, but still had a big gap between the chassis pans and the bottom of the body, around 1/2” or so. The battery was hitting the body. My first thought was to just hack it up and have the battery stick out and try to make some sort of ‘cover’ for it. My next thought was so a forward mount servo and lay the battery flat-that’s the winner! So I got to work. Grabbed the TRX4 brass bumper/servo mount and to my surprise it fit, cool. What didn’t fit was the steering link, so I made one with all thread and two Traxxas rod ends. Next came mounting everything. Here is where the first problem came. I had to cut the battery tray for it to clear, nothing crazy though. Now we have the servo in. here’s the problem that isn’t solved. As you can see, the servo is full lock to the right, but the wheels are still straight-no right turn. I have tried multiple things with no solution. Right now both endpoints are set for the stock 10.2 servo position, and I don’t know how to adjust it. I’m sure it’s something simple I’m not thinking of. If anyone knows how to change endpoints, please let me know. _________________ SCX10 ii TRX4 Last edited by ScaleLifeNewbie; 02-16-2021 at 06:06 PM. |
02-16-2021, 06:24 PM | #119 |
I usually like your mods brother but this one has a can of worms feel to it. Why not just find a body that fits how you want instead of re-engineering that chassis to slam that TW on it? And why is your shock zip tied to the tower lol Sent from my iPad using Tapatalk |
02-16-2021, 06:32 PM | #120 | |
I don’t know lol, I like the body and thought this would be a lot easier. If I can figure out the EPA’s then it’s golden. This isn’t my primary body anyway, I’ll mostly run the Bronco. I’m probably going to just put this on the back burner and put it back as normal. Oh yeah, zip tied shock is because I lost the screw that goes there so it’s like that for now until I can make it into town again lol. _________________ SCX10 ii TRX4 | |
SLN’s Axial Experience - Similar Threads | ||||
Your experience with Axial Rockster Beadlocks? | DrDiff952 | Axial Wraith | 15 | 01-14-2014 03:30 PM |
anyone had any experience with these? | slash 127 | General Scale Talk | 5 | 02-22-2013 04:52 PM |
Does anyone have any experience with.... | kaetwo | General Scale Talk | 4 | 07-16-2008 11:05 AM |
Anyone else experience this? | ecoli | Electronics | 7 | 04-16-2008 04:59 PM |
my 1:18 experience | dhoffroad | General Crawlers | 15 | 01-26-2006 10:53 PM |
