02-07-2021, 05:37 AM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Norway
| Hobbywing Fusion - kit transmission
I’m thinking of getting the Hobbywing fusion for my UMG10. Does the 550 lenght fusion motor fit the kit transmission in my UMG10? And what do you think of the speed with the 1800kv fusion. Is it to slow? I like a little punch in my trucks. |
02-07-2021, 06:18 AM | #2 |
Newbie Join Date: Sep 2020 Location: NW
| Re: Hobbywing Fusion - kit transmission
I don't have a UMG10, but I do have the 1800kv. I love it in my BOM, faster than a stock TRX4 in high and real nice slow crawling Sent from my SM-G781U using Tapatalk |
02-07-2021, 09:23 AM | #3 |
Rock Stacker Join Date: Dec 2020 Location: London, Ontario
I don't have the kit transmission, I run the AR10 RTR transmission and it bolts up just fine but the length was an issue. I had to cut out part of my battery tray to get the motor to fit. Its the same length as a 550 brushed motor. It is maybe a little faster than my stock 35 turn Axial motor was, but the low speed control is excellent. So far it's been a great motor and I have no complaints. However something I have noticed is that with the FOC on, you have a tendancy to be more aware of any slop in the drivetrain. |
02-07-2021, 01:49 PM | #4 |
Rock Crawler Join Date: Nov 2019 Location: Erie
Desmo, I have a UMG10 that I had a 550 brushed motor in with no issues. It was a 1750kv inexpensive motor and both the punch and low speed with the stock UMG10 gearing were quite good. The Fusion is known for incredible low speed and top end should be decent as well. I actually just picked up a 1800 Fusion and not sure if I want to put it in my new Gatekeeper build or my UMG10, which currently has a Holmes 2500 Revolver Snubnose in that I love. The Fusion would be a great choice for your UMG10 and wouldn’t have any issues fitting.
02-07-2021, 03:52 PM | #5 | |
| Re: Hobbywing Fusion - kit transmission Quote:
02-07-2021, 04:44 PM | #6 |
| Re: Hobbywing Fusion - kit transmission The UMG10 is a pretty light rig too so the Fusion should have plenty of rip, and they’re said to run cool so I wouldn’t be afraid to go up on the pinion if you need more top speed (of course temp it to be safe ). Enjoy and report back with your experience!
03-11-2021, 04:14 PM | #7 |
Newbie Join Date: Sep 2018 Location: Italy
Hi Desmo, any updates? I'm also looking to pair the fusion with the kit transmission, but I'll end up with an heavy rig, anybody could tell if I'll be in trouble? I plan to use the 1800 kV with a 11T pinion, mostly low speed crawling and trailing, nothing extreme. thanks! Last edited by RCPawel; 03-11-2021 at 04:44 PM. |
03-15-2021, 06:41 AM | #8 |
Rock Stacker Join Date: May 2020 Location: Compton
I think you’ll b fine. Have the same motor run n 3s with a 25 tooth pinion on my gatekeeper and it barely gets warm. Sent from my iPhone using Tapatalk |
Hobbywing Fusion - kit transmission - Similar Threads | ||||
New Hobbywing Quicrun Fusion 2-1 FOC Brushless motor/ESC Combo for Rock Crawling | soze | Electronics | 42 | 11-19-2021 04:05 PM |
Hobbywing Fusion | deephis46 | Electronics | 2 | 02-06-2021 06:49 PM |
HOBBYWING Fusion 1800KV | Rcing4life | Scale Videos! | 0 | 01-19-2021 12:14 PM |
Hobbywing QuicRun Fusion FOC? | derekmac | Axial SCX10 III | 6 | 12-04-2020 06:48 AM |
