Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: xj rtr light kit
Old 03-03-2021, 07:22 AM   #1
Default xj rtr light kit
what do I need to run lights on my xj? do I need to swap the esc? or can I just run a stand alone kit that plugs into the receiver?
Tim1987 is offline   Reply With Quote
Old 03-03-2021, 07:44 AM   #2
Default Re: xj rtr light kit
What receiver are you running? Does it have outputs for lights?
Sent from my GM1917 using Tapatalk
Mletchworth is offline   Reply With Quote
Old 03-03-2021, 07:51 AM   #3
its the ae5 non l (the standard xj one) no light outputs.
Old 03-03-2021, 08:04 AM   #4
Probably your best bet would be finding some lights that have a servo plug you can connect to the receiver
Old 03-03-2021, 09:15 AM   #5
Take a look at MyTrickRC. I have a kit for my TRX4, three levels of head light an running lights. With a y-splitter in channel two, you can get brake lights (zero throttle) and reverse lights. You just need to solder a jst plug into your battery lead to power the light controller.
Sent from my LM-V600 using Tapatalk
smc-93 is offline   Reply With Quote
Old 03-03-2021, 10:17 AM   #6
from what i saw on the my trick rc I can just plug to the receiver and power the lights from there?
Old 03-03-2021, 10:36 AM   #7
I think you can depending on the light kit and the controller it comes with. However I can't confirm that as it was never my intention to wire mine that way so I've never tried it. If you look on the MTRC site, the individual pages for various light kits should have a linked video with installation instructions. I'm sure you can find some on YouTube as well. I believe the "attack high power" LED headlights in my kit require more than the ~5.4 volts going to my receiver, hence the battery lead jumper.
Old 03-03-2021, 11:50 AM   #8
Are you doing a light bar or headlights and taillights?
This is a cheap 90mm light bar running off receiver power 6V.
xj rtr light kit - Similar Threads
In Stock - New MyTrickRC Attack LED Light Kit w/ 5" Light Bar for TRX-4 Defender! RPP Hobby RPP Hobby 1 10-11-2018 01:32 PM
Axial RTR Wraith light kit DrDiff952 Electronics 1 05-06-2014 12:51 PM
