Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: ssd overdrive gearset
Old 03-09-2021, 08:39 AM   #1
Default ssd overdrive gearset
do these come with the shims you may need or where do I purchase those?
I have read that it is not good for a trail truck but this is my only rig.
Tim1987 is offline   Reply With Quote
Old 03-09-2021, 08:48 AM   #2
Default Re: ssd overdrive gearset
You may or may not need to shim. Iíve built 3 axles, one needed shimming the others didnít. I had some left over from a vanquish VS4 build
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 03-09-2021, 08:53 AM   #3
is there a part number for the shims?
Old 03-09-2021, 09:25 AM   #4
Slow is the new Fast
smog's Avatar
I believe they come with a small shim. Like Mike, never used it. toyed with the idea but it made the diff too tight. I have now bought a couple of SSD OD gear sets and haven't needed to shim.
smog is offline   Reply With Quote
Old 03-09-2021, 11:44 AM   #5
Thanks for the reply. do you trail any of yours as well or just crawl?
Old 03-09-2021, 02:18 PM   #6
I strictly crawl. The latest rigs running these are my SCX10III, and my newer Sherpa build . Both are running more OD, with TGH parts on both
Hang up and Drive
Old 03-10-2021, 09:59 AM   #7
Had to shim mine with the ar44 difs but not the ssd difs. Mine have never come with shims, but I bought a selection a few years ago as I use them quite a bit.
Xx Losungen xX is offline   Reply With Quote
Old 03-10-2021, 11:29 AM   #8
Yeah these do not include shims. I've never had a plastic axle that didn't require some shimming, I think everyone has different standards for shimming though. For me I want all side to side play eliminated on the ring gear/spool then I ensure there is some play between the pinion and ring gear but not too much by adjusting which side the shims go on.
I use these shims https://www.amainhobbies.com/crc-7mm...cln4737/p53205
I have a few rigs that see some trail duty with overdrive, in the dirt I dont worry because the tires can slip. If on the other hand you're running down a long road or something then I'd be a bit more concerned in terms of wear and tear.
HumboldtEF is offline   Reply With Quote
Old 03-10-2021, 02:51 PM   #9
smog's Avatar
I do both. I trail run slowly though. I
ssd overdrive gearset - Similar Threads
SSD Overdrive Gears food2000 Axial SCX10 III 3 11-08-2020 03:38 PM
New SSD Overdrive Gears SSD Axial SCX10 II 73 10-09-2020 02:50 PM
