Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: best end links?
Old 04-08-2021, 07:44 AM   #1
Default best end links?
looking at these but will need new end links
https://www.hobbytown.com/samix-scx1...5025fs/p991023
Tim1987 is offline   Reply With Quote
Old 04-08-2021, 09:47 AM   #2
Default Re: best end links?
I to have wonder what the best alternative is, Does anyone have any experience with these?
https://www.amazon.com/Que-T-Metal-C...s%2C469&sr=8-5
Den72 is offline   Reply With Quote
Old 04-08-2021, 09:50 AM   #3
In my experience, metal end links are a bad idea. They have a ton of slop in them.
MrAwesome987 is offline   Reply With Quote
Old 04-08-2021, 10:24 AM   #4
Traxxas rod ends are excellent, I've never had any issues with them whatsoever.
They use just the right type of plastic - not too rubbery and not too brittle.
The TRX4 rod ends are available in standard, extended length, angled, and offset.
(friends don't let friends use metal rod ends!)
durok is offline   Reply With Quote
Old 04-08-2021, 10:30 AM   #5
Metal rod ends - bad idea. Can lead to breaking more expensive parts like skid plates and axle mounts.
Traxxas rod ends are the best there is imo.
QuesoDelDiablo is offline   Reply With Quote
Old 04-08-2021, 10:32 AM   #6
how many of which do i need for an scx10ii?
Old 04-08-2021, 11:41 AM   #7
So what is it I need for the wraith spawn?
Old 04-08-2021, 12:27 PM   #8
For a Wraith I would upsize to the Traxxas Revo and/or Jato rod ends - super burly!
My Bomber has been upgrade with them (among other upgrades) - they are of slightly different lengths - Revo ends are shorter and more commonly used, but if you need to add a bit of length to a link you can use the Jato ends.
https://www.rpphobby.com/product_p/tra5347.htm
https://www.rpphobby.com/product_p/tra5525.htm
Old 04-08-2021, 02:36 PM   #9
Thank you for the feedback, Looks like I will be doing some upgrades. I have seen rod ends break on the trail and don't want to be towed back to the truck.
Old 04-12-2021, 07:23 AM   #10
https://www.hobbytown.com/samix-stai...bfs-58/p578279
thoughts
Old 04-12-2021, 10:29 AM   #11
Like anything, there's a trade-off.
Those balls would last a looong time but they'll wear out end links quite badly.
I used run aluminum balls all the time (and I still do quite commonly), but I'm starting to see the benefits of running plastic balls because they tend to be cheaper to replace than rod ends.
best end links? - Similar Threads
Using upper links for bottom links? I've hit a dead end! TIME MACHINE Axial AX10 2nd-gen 2 03-05-2015 12:00 AM
End links. Tim Steele Newbie General 13 07-21-2013 02:48 PM
end links amatuer33 RC4WD Bully 9 10-15-2011 08:58 PM
aluminum links and end goingvertical General Crawlers 10 12-27-2005 03:33 PM
Exact length of links from end of ball end to other? ccampb04 Tamiya TLT Crawlers 5 04-12-2005 12:01 AM
