Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Per axial blog, stock rear springs to front, and front to back?
Old 04-11-2021, 06:48 PM   #1
Default Per axial blog, stock rear springs to front, and front to back?
Anyone done this?
I took my new build out the other day with stock springs and shocks in the factory locations it says to put them, and it did OK i thought.
I came across the blog that mentioned putting the softer springs in front from the rear and moving the stiffer fronts to the rear, and then angling the rear springs leaning toward the front.
I did this and took it out a bit ago, but to me, the front maybe seems too soft now? I dunno...I have alittle bit of preload on the adjusters, but now with it like this my tires rub on my fenders very easy in the front now on my pro-line gladiator body.
Who else is running like this?
93civEJ1 is offline   Reply With Quote
Old 04-11-2021, 10:29 PM   #2
Default Re: Per axial blog, stock rear springs to front, and front to back?
Iím running that setup on my Deadbolt, itís definitely super soft up front and rubbing aplenty lol
Battleborn7 is offline   Reply With Quote
Old 04-12-2021, 07:43 AM   #3
Do you like it that way?
Old 04-12-2021, 07:10 PM   #4
Both my Honcho and my RBK, are running that way. I like it for climbing performance and the lower cg provided by lower ride height.
RBK... F150, Honcho is Honcho, lol
lonleycreeper is offline   Reply With Quote
Old 04-13-2021, 11:18 AM   #5
i got to take it out to one of the local spots yesterday. I ended up liking it ok. its not as bad as I thought it was going to be.
Old 04-13-2021, 04:55 PM   #6
I do like it, I’m also now running the 100mm aluminum shocks that came with my 10.3 straight axle kit. Plenty of down travel, but more importantly the soft springs up front compress on steep rocks and climbs instead of unloading and tipping me over backwards
Per axial blog, stock rear springs to front, and front to back? - Similar Threads
Front or Rear springs XJ96PA General Crawlers 5 08-30-2005 07:47 PM
