Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Strong AR44 gears?
Old 04-22-2021, 02:13 PM   #1
Default Strong AR44 gears?
What are some strong AR44 gears that aren’t Underdrive for the rear? Broke 17 teeth on my ring gear lol.
_________________
https://www.instagram.com/island_crawlaz/
79 F150 SCX10 ii
TRXWalker
ScaleLifeNewbie is offline   Reply With Quote
Old 04-22-2021, 02:48 PM   #2
Tiny Truck Hoarder
HumboldtEF's Avatar
Default Re: Strong AR44 gears?
Axial:https://www.rpphobby.com/product_p/ax31405.htm
VP: https://www.rpphobby.com/product_p/vps08330.htm
SSD: https://www.rpphobby.com/product_p/ssd00181.htm
Which gears did you munch? Were they the sintered ones? I've never had issues with the above gear sets, these are all hardened steel.
HumboldtEF is offline   Reply With Quote
Old 04-22-2021, 03:15 PM   #3
Just to add, for the VP or SSD Gear set, make sure you get the 6 bolt locker as well if you don't have it already.
food2000 is offline   Reply With Quote
Old 04-22-2021, 03:23 PM   #4
Thanks!
Yep, the sintered ones.
_________________
79 F150 SCX10 ii
TRXWalker
Old 04-22-2021, 05:45 PM   #5
I’ve had good luck with my ssd overdrive gears. Just ordered ssd standard gears for another build. The only underdrive ring and pinion you’ll find is from vanquish. But as stated, be sure to buy the 6-bolt spool
Fricker08 is offline   Reply With Quote
Old 04-22-2021, 06:44 PM   #6
Thanks Fricker! I’m about to order the SSD 30T/8T combo and the 6-bolt locker.
_________________
79 F150 SCX10 ii
TRXWalker
Old 04-22-2021, 07:08 PM   #7
Gold Star Baby!
Topher Builds's Avatar
I’ll throw out that some people, myself included, have struggled getting good mesh with the Ssd overdrive gears in non-Ssd housings so keep that in mind. Not sure if they were ever updated or even planned on being updated.
Love me some Ssd but I’ll stick to boom racing, hot racing, or axial for optional gears since those have all fit well for me in other rigs. One day I’ll get some vp UD gears.
Topher Builds is offline   Reply With Quote
Old 04-22-2021, 07:09 PM   #8
The ring/pinion and locker I got from Amain said (UPDATED!) in the name so, I think they’re updated lmao.
_________________
79 F150 SCX10 ii
TRXWalker
Old 04-22-2021, 07:32 PM   #9
Tiny Truck Hoarder
HumboldtEF's Avatar
While I agree that the SSD gears are a bit on the tight side I've never had them fail, when shimming them there seems to be no perfect outcome. Over time im sure they free up a bit. Some folks have definitely had issues though.
I think the updated note on the SSD product page is referring to the 6 bolt vs 3 bolt pattern.
Old 04-22-2021, 07:49 PM   #10
Ah okay, I wasn’t aware they were ever a 3 bolt.
The stock AR44 gears were super rough at first, but over time they got buttery smooth. I’m sure they’ll be fine.
_________________
79 F150 SCX10 ii
TRXWalker
Old 04-22-2021, 07:51 PM   #11
Gold Star Baby!
Agreed and agreed.
I had issues with them in a Capra axle but they never failed, just toight like a toiger. Chewed the locker a tad even. If I recall correctly I’ve since moved them to one of the several Ssd axles I have, and they’re still running strong.
Old 04-22-2021, 09:19 PM   #12
I've never had issue with the SSD gears in Axial or SSD housings. They're certainly made to a tighter tolerance and in my opinion all almost all gears require shimming, maybe I'm just ocd and hate slop.
Xx Losungen xX is offline   Reply With Quote
Strong AR44 gears? - Similar Threads
Boom racing ar44 overdrive gears. Who has experience with them? Bard Axial SCX10 II 11 01-05-2020 09:32 PM
HR 27t/8t Underdrive gears for ar44 MattySlimz1987 Axial SCX10 II 39 10-30-2018 11:31 PM
AR44 Overdrive Diff Gears mikebecher Axial SCX10 II 12 03-25-2017 01:57 AM
