Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: First SCX10 ii
Old 05-19-2021, 09:59 AM   #1
Default First SCX10 ii
Well just as the title says this is my first scx10 ii. I got it in on trade. It's somewhat built already but there's things I want to change to make it my own truck and to fit my style of driving. First question is, is the supershafty bombproof trans about the same size as the factory trans from the Cherokee kit?
Beerleaguebasher is offline   Reply With Quote
Old 05-19-2021, 10:59 PM   #2
Default Re: First SCX10 ii
did you trade your VS4-10 for this?
Sniper4370 is offline   Reply With Quote
Old 05-19-2021, 11:07 PM   #3
Yes I believe he did.....
_________________
TF2 Marlin
SCX10ii Bronco
TRX10.4
Instagram: Island_crawlaz
ScaleLifeNewbie is offline   Reply With Quote
Old 05-20-2021, 08:22 AM   #4
Yes i did. I know most of you wouldn't have done it but i was looking to get something else. I'll get another vs410 in the future it won't be the last one i own.
Old 05-24-2021, 02:26 PM   #5
Well after a closer look and so dismemberment of the truck, it has more stuff the needs done then I thought. Going it strip everything this winter sandblast the cage and get it powder coated. Strip the interior and re paint it and add some little touches to make it look a little better. Rework the electrics, so the esc has a little more room to breathe. Make some sheet metal panels for the body and the back of the dashboard. Try to find some vanquish rockjock axles, to replace the SSD d44 pro axles. Possibly change out the wheels. Replace the shocks to make it sit a little lower. But for now, going to change all the bearings, replace all the miss matched screws and switch the gears in the trans and axles to incision gears. Already took the spare tire of since it wasn't a matching tire or wheel.
Old 05-26-2021, 02:36 PM   #6
Got all the electronics soldered up. The interior is completely torn out and looking to fix it up a little bit. But have to stop working on it, so I can get my element sendero ready for crawling this weekend.
First SCX10 ii - Similar Threads
SCX10 axle upgrade, SCX10.2 vs SCX10.3 axles?! BJoe Axial SCX-10 20 03-28-2021 06:05 PM
New Lost Coast Backwoods RC Low CG Battery Boxes for SCX10 and SCX10 II! RPP Hobby RPP Hobby 0 08-07-2017 03:38 PM
Axial SCX10 ll, SCX10, Gmade Sawback 4LS, Vaterra Ascender K5 From Malaysia. RCWin Videos! 2 12-01-2016 09:23 AM
