03-02-2022, 08:39 AM | #1 |
Newbie Join Date: Mar 2022
| Scx10ii - phat axle
Hello all! I have the the Raw Builders Kit from Axial. The axle is changed to Boom Racing Phat Axle. The shocks are RC4WD King 90mm. When I push down the two front shocks at the same time, the whole chassis with the body go to the right about 0,5 cm… Do you know what causes this problem amd how can I get rid of it? Thanks! |
03-02-2022, 08:50 AM | #2 |
| Re: Scx10ii - phat axle
it is what it is theres not realy a easy way around it the suspention was designed to work like that the 3 link was designed as a comprsmise from the get go works ok on stock ride hight but our scale rigs have what would be considered a huge lift and huge lift + 3 link = axle swing so basicly dont push down on it while looking at it and you wont have a problem lol |
03-02-2022, 09:09 AM | #3 |
So is there no way to make it “normal”? Does not look scale this way. I have not realized it yet. But now it bothers me a lot. Thanks for the answer! |
03-02-2022, 09:51 AM | #4 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
Keep in mind, when driving your truck it will almost never compress both front shocks at the same time. It is a function of a 3-link with panhard that the axle will follow the arc of the panhard, some more so than others. I don’t know the specifics of your setup in particular, perhaps changing the axle or shocks has increased this, I’m not sure. Sent from my iPhone using Tapatalk |
03-02-2022, 10:35 AM | #5 |
Thanks
03-02-2022, 03:59 PM | #6 |
RCC Addict Join Date: Sep 2010 Location: Apollo Pa
Any time a change is made in the suspension from stock the geometry will change, in your case you have non stock axles and shocks and who knows what else, if you bought it this way your going to have to experiment with it to get it to your liking, usually it takes changing the panhard length to compensate for nonstock parts, it's really really hard to give you definitive answer without seeing it though, I just know there have been times where I have bought a rig here and there that had aftermarket parts and some adjustments had to be made. Is your steerring link parallel with the panhard link? If not that's a good indication something isn't right.
03-03-2022, 06:16 AM | #7 |
I had the Raw Builders Kit and I bought these parts myself to it. Yes they are parallel. |
03-03-2022, 06:20 AM | #8 |
| Re: Scx10ii - phat axle Everyone is on point, it's a function of the 3 link/panhard setup, regardless of axle housing or shocks installed. Only way it can be removed completely is to convert over to a 4 link front suspension with a servo on axle. |
03-03-2022, 08:00 AM | #9 |
Rock Crawler Join Date: Nov 2019 Location: Erie
| Re: Scx10ii - phat axle Well said! People who are die hard “scale” guys are not fans of SOA/4-link setups. My rigs that came stock with 4-link and my “EctoKeeper” that I converted to 4-link definitely handle and steer better than my 3-link/panhard rigs. I like my rigs to look good, but I’m absolutely a performance first guy. Lol
03-03-2022, 08:03 AM | #10 |
| Re: Scx10ii - phat axle |
03-03-2022, 08:07 AM | #11 |
The shocks are 90mm long.
03-03-2022, 09:54 AM | #12 | |
Pebble Pounder Join Date: Oct 2019 Location: Saint Louis
| Re: Scx10ii - phat axle Quote:
Sent from my iPhone using Tapatalk | |
03-03-2022, 12:20 PM | #13 |
03-17-2022, 02:42 PM | #14 |
I managed to solve the problem thanks for the support. I only had to change the lenght of the panhard and the servo arm. BUT! I have again a queston... Does this item Z-S1827 fit to the SCX10II bumper mount (~43-45mm) |
03-17-2022, 02:44 PM | #15 |
12-12-2022, 09:22 PM | #16 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
12-13-2022, 07:58 PM | #17 |
Quarry Creeper Join Date: Dec 2012 Location: Toxaway
12-13-2022, 10:58 PM | #18 |
12-13-2022, 11:30 PM | #19 |
There's also the option to 4 link it, and keep chassis mounted servo. Pretty much like a wheely king steering setup.
Scx10ii - phat axle - Similar Threads | ||||
Boom racing Phat axle xr mod | Johan_Eriksson | Axial SCX-10 | 5 | 11-04-2018 12:18 PM |
Boom racing d90/110 phat axle experiences? | scalemadness | General Crawlers | 5 | 06-17-2017 04:29 AM |
