Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Driveshaft angle
Old 07-04-2022, 09:15 PM   #1
Default Driveshaft angle
Is there a way to have the driveshaft angle not quite so steep? I have run a few crawlers with a steep angle, but I'm working on a build and I'm about to buy some driveshafts but the angle has me worried- nothing radical here just a stock deadboltII frame and servo on the axel. any ideas? Trying to reduce binding as much as possible- Thanks Vic in Utah
oldblue2010 is offline   Reply With Quote
Old 07-04-2022, 11:12 PM   #2
Default Re: Driveshaft angle
You can lower the transmission to the skid. Shave the transmission side down and/or hollow out the mounting area of the skid.
Goro Majima is offline   Reply With Quote
Old 07-05-2022, 12:14 AM   #3
you could angle the pinnions up twards the trans that helps alot
you could lower the trans or skid like sead above
you could use a different frame say a trx4 that has a much lower belly a vanquish frame is vary close to the trx4 belly hight
you could switch to portal axles
you could use shorter shocks or limit droop
good driveshafts should handle the angle
ferp420 is online now   Reply With Quote
Old 07-05-2022, 05:52 AM   #4
If you wanted to make or order some new links you could make the top links longer. But it will change your steering angle a bit too. I've done it twice and it works like a charm.
T I N Y is offline   Reply With Quote
Old 07-05-2022, 01:14 PM   #5
The pinon agle seems like a good idea- can you point the way on how to do it please?
Old 07-06-2022, 02:21 PM   #6
If your pinion and trans output are not parallel to another, it will create a lot of vibration/heat on something that goes fast. If you are only going slow, then the pinion angle would help out in the rear. If you can clock the front knuckles, then ....
Gula is online now   Reply With Quote
Driveshaft angle - Similar Threads
Driveshaft angle after Tummy Tuck Mod? TheWraithofGod Axial Wraith 1 12-21-2016 08:36 AM
Driveshaft with steep angle capability's Brehrocks Axial SCX-10 12 09-27-2014 01:42 PM
driveshaft angle scx10mudder Axial SCX-10 4 03-29-2011 12:07 AM
Driveshaft angle? jgammill Axial SCX-10 6 03-01-2011 02:23 PM
BB-51 front driveshaft angle JasonInAugusta General Scale Talk 33 03-12-2007 06:52 PM
