04-05-2020, 02:24 PM | #41 | |
| Re: Bud Quote:
04-05-2020, 04:17 PM | #42 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: Bud
How did you route your steering servo and motor wires with the faux motor and front pulley/belt accessory to contend with? I don't think I've ever wish I could've mounted a servo with the wiring plug to the rear more!
04-05-2020, 06:00 PM | #43 | |
| Bud Quote:
Motor leads go under the rear brace along with the sensor wire(braided in pic) the servo lead go the other direction.I have a lot of room with the Holmes 2700 Stubby.Only issue I had was to make a 4” servo extension for the dig servo Hang up and Drive Last edited by mikemcE; 04-06-2020 at 10:01 AM. | |
04-05-2020, 07:44 PM | #44 |
| Re: Bud
Clear, thanks for the pic! I'm going to have to get creative.....
04-06-2020, 09:47 AM | #45 |
| Re: Bud
Came out great!
04-07-2020, 06:17 AM | #46 |
| Re: Bud
As I was watching your latest YT video, I was thinking that it sounded quieter than most. Glad to hear yours doesn’t have that clicking noise! Rig turned out great Mike! Sent from my iPad using Tapatalk |
04-07-2020, 06:32 AM | #47 | |
| Re: Bud Quote:
I think so also. When I built the transmission I greased the shafts, and dogs well. This is the only thing I might have done to keep the clicking down, and running the single speed. I also have OD gears in the diff, with Capra OD gears coming, OD usually makes for a bit more noise Hang up and Drive | |
04-07-2020, 01:06 PM | #48 |
| Re: Bud
Well I had to go to work today for a bit, took Bud with me, so we hit the rip rap that I’ve always used. Anyone who says these tires don’t..... is wrong! It was HOT in the sun(92) so everything was also hot . This truck if the tires could grab an edge, I was up. Even the vertical entry, fronts on rock, rear in sand, UP I Went..... no dig used, yes I am running axial OD gears, and a 12t pinion on 3s, the stubby only spun the slipper once!! Can’t wait for a bit of weight. Hang up and Drive |
04-08-2020, 07:21 PM | #49 |
Newbie Join Date: Mar 2020 Location: Normandy Park
| Re: Bud
Sweet!
04-09-2020, 05:54 PM | #50 |
| Bud
OD , yup we’ve got it now. Axial in the pumpkin. Hot Racing in the portals. Added some VP cromoly stub shafts and a set of SSD hexes that match the SSD portal covers Hang up and Drive |
04-09-2020, 05:59 PM | #51 |
| Re: Bud
Well that didn't take long!
04-09-2020, 06:48 PM | #52 |
| Re: Bud Well I built it with the “OD” gearset I had here .and while it’s very capable, I just put the OD gears in my VFD, after enjoying them in the wife’s Enduro, and I needed more, as this is a climber.I usually add brass knuckles, but the portal covers seemed perfect weight wise. I’m still not happy with rear shocks, I think those big holes in the valves want 70 weight not 45 Hang up and Drive |
04-09-2020, 07:02 PM | #53 | |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
| Re: Bud Quote:
04-09-2020, 07:20 PM | #54 | |
| Re: Bud Quote:
04-09-2020, 07:27 PM | #55 | |
| Re: Bud Quote:
The 35 up front is okay... with the extra weight and grip, I may need to go up to 45 to 55.... I’m not sure if 60 or 70 will work better, if I don’t flush them out completely, I might end up with 65 | |
04-11-2020, 06:55 AM | #56 |
| Bud
Went to 70 in the rear, seems much better, one bleeder screw won’t seal, plastic caps! Hang up and Drive Last edited by mikemcE; 04-11-2020 at 09:00 AM. |
04-11-2020, 09:06 AM | #57 |
| Re: Bud
Major difference in sidehilling... plants nicely now, no rear weights. Might go to 45 up front, I did adjust preload and seems much better. Hang up and Drive |
04-11-2020, 01:29 PM | #58 |
| Re: Bud
Looks great Mike!!! Did you end up using 70wt in the rear?
04-11-2020, 02:24 PM | #59 |
| Re: Bud |
04-11-2020, 02:52 PM | #60 |
| Re: Bud |
Bud - Similar Threads | ||||
Tf2 bud naked | Sqbiedoo | RC4WD Trail Finder 2 | 4 | 05-27-2013 11:37 AM |
bud rims 1st look | SEMIJOE | Non Crawler RC's | 4 | 11-10-2010 03:05 PM |
Bud #8 Slash | TIMZKRAWLER | Non Crawler RC's | 14 | 08-12-2008 04:01 PM |
