03-28-2020, 06:06 PM | #1 |
Newbie Join Date: Nov 2019 Location: Cypress
| what micro servo for dig and transmission
I've read that several people have had issues with the spektrum sx107 micro servo used in the capra for the dig , so what other micro servo are yall using or would you recomend?
03-29-2020, 02:44 AM | #2 |
Newbie Join Date: Oct 2019 Location: Iceland
| Re: what micro servo for dig and transmission
I'm using PowerHD TR-4 in my Capra. It is designed for TRX4, but works much better than SX107. It is digital, waterproof and 7,4 V compatible.
03-29-2020, 03:47 AM | #3 | |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
| Re: what micro servo for dig and transmission Quote:
03-29-2020, 04:14 AM | #4 |
Yes, same size, just a bit wider holes for bolts. I use 25T horn supplied with PowerHD servo. No servo saver.
03-29-2020, 07:36 AM | #5 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
The other option stock Traxxas trx4 diff/shifter servo saver
04-02-2020, 03:27 PM | #6 |
Newbie Join Date: Apr 2020 Location: Sunol
The SX107 comes with a piece that connects the servo to the servo saver in the kit. For whatever reason the kit does not come with this part. I understand that there are different sizes but the kits used to come with the 2 or 3 different servo output sizes. I have some micro servos from my heli's but the servo horn does not really work with the dig or 2 speed. Is there a kit or something we can order to fix this or do we just have to modify the servo horn to get it to work? I dont see why the SX107 is the only option covered by Axial considering the feedback people have left about it and the fact that it is sold out everywhere. Thanks |
04-02-2020, 03:40 PM | #7 | |
I wanna be Dave Join Date: Sep 2019 Location: US
~ More peace, love, laughter & kindness would make the world a MUCH better place | |
04-03-2020, 11:24 AM | #8 |
Newbie Join Date: Mar 2019 Location: Thousand Oaks
This is a HUGE oversight in my opinion. You basically have to use the Spektrum servo in order to get the bottom piece of the servo saver. Why on earth wouldn't Axial\Horizon have just molded that piece along with the other two parts that are included in the kit. Manual and box just state you need "2 micro servos" to complete but the fact of the matter is you need "2 Spektrum spmssx107 micro servos" to complete. I bought two eco-power 640T's when I bought the kit thinking they would work without modification. Now I either have to engineer a way to connect them without a servo saver or exchange them for the Spektrum servos when they eventually come off of backorder and rebuild the trans to go without them for the time being. Last edited by tdo805; 04-03-2020 at 11:27 AM. |
04-03-2020, 11:56 AM | #9 | |
If you use a servo horn instead of a servo save your should be able to make those servos work. I will say I haven't had any issues with the Spektrum micro servos. Granted, I've only run my Capra a couple of times though. If you set your end points CORRECTLY, they should be just fine. | |
04-03-2020, 02:13 PM | #10 | |
04-03-2020, 02:29 PM | #11 |
| Re: what micro servo for dig and transmission The Capra is no different than the SCX10 III in that you need the servo to get the other part of the servo saver. Half of the servo saver comes only with the servo itself.
04-03-2020, 02:33 PM | #12 | |
*edit* - went back and read the first couple posts of the thread and now realize why my coment didnt make any sense Last edited by tdo805; 04-03-2020 at 02:55 PM. | |
04-03-2020, 03:53 PM | #13 |
You can buy only the plastic part separately, without buying the servo
04-06-2020, 11:34 AM | #14 | |
Axial Racing - 2-Speed Hi/Lo Servo Saver Set | |
04-10-2020, 11:04 AM | #15 |
Be wary with the AX31009. I got the kit and tried it with a Hitec and eFlight micro servo and the kit does not have a small enough adapter, the smallest is 23 tooth. They really need to fix this oversight. It does not make sense. I don't want to use it without a servo saver and with the reputation that the Spectrum one I don't want to waste my money on that servo. Hopefully they make a kit for this sooner than later.
04-11-2020, 09:35 AM | #16 |
Rock Stacker Join Date: Jan 2017 Location: Chicago
I guess I see it like this. I got the spectrum servos. They have the hardware needed. It was the cheapest and available option at the time of ordeing. When they fail, I have my eye on these. https://www.savoxusa.com/products/sa...g-high-voltage The other thing I am not liking about the spektrum servos, is there is no specs on them anywhere. Not on the website, or the package when you get them. My $.02, FlatLander Sent from my Moto Z (2) using Tapatalk |
04-11-2020, 10:46 AM | #17 | |
04-11-2020, 12:29 PM | #18 |
I ended up exchanging my eco power servos for the spectrum ones and made sure my endpoints were adjusted so the servos weren’t straining at the ends of the throw. Guess we will see how they hold up. I’m not super happy with how the wire on the shift servo routes either but I think it would be that way regardless of servo I used. 🤷🏽*♂️
what micro servo for dig and transmission - Similar Threads | ||||
DNA Dig Custom Servo Mounts, Full Size or Micro Servo | Kraqa | Axial AX-10 Scorpion | 12 | 09-11-2009 10:17 AM |
