Esc placement and wire routing How is everyone routing wires and where are you placing the ecs and battery? After screwing around with it for a while, this is what I think ill end up with. But I'm open to suggestions. Post pics of your setup please. http://img.photobucket.com/albums/v6...psk4qldydt.jpg |
Re: Esc placement and wire routing https://uploads.tapatalk-cdn.com/202...47de1c3bcc.jpg This is mine with the mytrickrc rock light wiring installed. I did move the loom off the fender too the body mount support to clear the body interior. Sent from my iPhone using Tapatalk |
Re: Esc placement and wire routing Just a word of caution with that type of loom. It can hold water and dirt, chafing wires and breaking down insulation. Also be sure to not have any stress on the loom, it can burn through the insulation eventually. |
Re: Esc placement and wire routing |
Re: Esc placement and wire routing Wiring nightmare https://uploads.tapatalk-cdn.com/202...3a36b6c2b4.jpg Sent from my SM-G930T using Tapatalk |
Re: Esc placement and wire routing This is what the spaghetti looks like so far. Still a ton to add. Waiting on a Futaba 7PX-R. After the budget recovers from that capital purchase, we will be looking to add a switchable light kit, ESS Dual sound kit, and a winch controller.https://uploads.tapatalk-cdn.com/202...77ab559234.jpg Sent from my Moto Z (2) using Tapatalk |
Re: Esc placement and wire routing I put all my electronics on the same side, similar to what flatlander did. I also routed the motor and servo wires under the chassis brace and motor cover so the least amount of wire is exposed. It is pretty clean. I also put my switch right near the opening where the links can be seen, so the switch is accessible from the underside while the body is on. I'll post some pics once I figure out how to do it. |
Re: Esc placement and wire routing Quote:
Re: Esc placement and wire routing My setup. I'd like to lenghten the motor wires and clean then up a bit with the braided over sleeve once I get some on hand. I also placed the on/off switch so i can access it from the bottom with the body on. https://lh3.googleusercontent.com/zr...-no?authuser=0 |
Switch. I’ll have to try that Sent from my iPhone using Tapatalk |
Re: Esc placement and wire routing 2 Attachment(s) Finally got mine somewhat buttoned up, I’m going to remove the full size tray and move the shorty tray to the back, but leave the esc there. |
Re: Esc placement and wire routing Any picture with a mamba X and bot micros and the side battery setup? |
