06-16-2020, 05:46 PM | #1 |
Newbie Join Date: Jun 2020 Location: Southwest
| Custom Axial SCX10.3
Hello, New to the forum, looking for some answers to a question I can’t find on the net. I’m looking to build a Axial SCX10.3. I am wondering if anyone knows if the Traxxas TRX4 axles will fit under the kit, I’d like to build a SCX10.3 with 2-speed, Dig, & front/read remote locking diffs. In a perfect world I would be able to put the axles and servos from my TRX4 into the JLU build a awesome crawler, then swap the Axial axles into the TRX4 and build a mud bogging beast! Thanks for the help! |
06-17-2020, 10:57 AM | #2 |
| Re: Custom Axial SCX10.3
Any one with the kit, can they get me these dimensions? I can pair them up with my existing TRX4 kit. |
06-17-2020, 11:09 AM | #3 |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
Ooh, fun idea. I can't help you much. I do wonder though if the 10.3's off centre front driveshaft would be a problem for the TRX 4 axles, and suspension link clearance. The 10.3 already has a funky panhard bar. |
06-17-2020, 12:01 PM | #4 | |
| Re: Custom Axial SCX10.3 Quote:
I have been talking with AXIAL tech support, they are looking into getting me the dimensions I need, but they actually reminded me I can buy the housing halves and just try to bolt them into to my TRX4. can anyone confirm, the Part numbers for the front and rear housings halves? Thanks, Joe | |
06-17-2020, 05:44 PM | #5 | |
RCC Addict Join Date: Jun 2008 Location: Mudville
I also grabbed the Radio Link RS6FG Tx/Rx (few rxs). It is also a very nice radio for the 70ish dollar tag for the radio and one rx. additional rxs are cheap and its HEAVY on Settings. Every channel has a number of adjustments and all channels can be mixed. the new 7 chnl rx also give Rig Battery Level Telemetry (22-25.00 for the 7 chnl rx) | |
06-17-2020, 05:46 PM | #6 |
As far as the II or III I have no Exp with either. My last Axial was the orig AX10 Scorpion. LOL But I did grab 2 of the SSD (ax10II upgraded kits) and they are nice but have upgrades. SO I basically have 2 SCX10II kits. lol in some way, both are still being built. Been looking at the III myself. Thought about the TRX Locking diffs myself. I don't have a III to measure but the dimensions should be available on the website to compare to the TRX axles. |
06-17-2020, 06:35 PM | #7 | ||
I was able to confirm the part numbers from Axial, I ordered them from my local shop, I suspect they will arrive in about a week or so. I will attempt to install the housing halves in my TRX4 & fingers crossed they fit, if they do then I am going to pick up the SCX10.3 kit in the next few weeks and start that build! Thanks for the help, photos to come! Joe | ||
06-22-2020, 07:45 PM | #8 |
Update: I received the SCX10.3 front housing 1/2. Removed my TRX4 front axle and connected the hosing 1/2. I am fairly confident that the TRX4 axles will fit under the SCX10.3 chassis, all of the links fall in similar locations, however the length of the links will need to modified. The upper link would need to be shorter and the lower links would need to be lengthened to correct the driveshaft angle as well as bring the castor and steering angle back to normal. Things I am a worried about: 1)I will need to lengthen the steering link, if it’s not parallel and of similar length to the track bar It will end up with bad bump steer, and I would think that can eat servos.. 2)I will need to get longer and shorter links, I feel like sourcing them is going to be hard. 3)The rod ends links on the TRX4 are a a bit thinner, and the shocks on the TRX4 are a bit wider so that will need to be addressed. I would post photos but I’m not sure I can, and I’m also not 100% sure how to. I think I’m going to take on the challenge, I might grab the SCX10.3 next week. More to come! Joe |
06-23-2020, 06:42 AM | #9 |
Quarry Creeper Join Date: Mar 2014 Location: Masshole
I can't wait to see your results and how much was involved. Keep us updated! |
06-23-2020, 07:34 AM | #10 | |
I think it should be pretty cool once it is complete, it will be like a real Rubicon. Have you read/heard/seen anything about the steering link/trackbar change on these little rigs? I know in full size trucks the trackbar/panhard is typically responsible for all of the problems (death wobble & bump steer) Joe | |
06-23-2020, 07:41 AM | #11 | |
07-22-2020, 06:20 AM | #12 |
Update: "Real Rubicon 10.3" Here is the build so far: HH 3500KV Puller Pro Castle MambaX 3Brothers G11 Str servo Savox SH0262MG Dig servo AGFrc 9G (amazon specials) Fr/RR diff servo Traxxas 2065 2-Speed Vanquish bead lock wheels RC4WD 1.9 TSL swamper boggers TRX4 Front and Rear Axles Flysky 6ch RX/TX Building the kit was an adventure, anyone that is going to build one I HIGHLY recommend you read through the sticky thread, it was super helpful, because the directions are not very clear at all. 1)I can confirm you will need a 3MM tap, the shock towers are not tapped, the holes strip if you try to crank the screw in by hand. 2)Be sure to have a MM ruler, there is nothing for reference in the manual and the packs of screws do not make any sense. On to the questions: I have the TRX4 axles mounted up, but because I used a combination of factory TRX4 and 10.3 links to set them up I am not sure if I am even close to the correct locations for the wheel base or even location of the axles in relation to the wheels wells of the body/fenders. If possible, can someone that has a 10.3 measure the wheel base, center of the front wheel to the center of the rear wheel? I need measurements from: Rear lower link mount chassis to the center of the Rear wheel. Front lower link mount to center of the front wheel. (There are 2 screws that hold the transmission to the belly that would be a easy spot to use as the "center" ) Lastly if possible, if someone can post a clear photo of the front shock position in relation to the axle, I know the factory kit the front shocks are mounted at an angle but I am unsure how drastic that angle is. After I get the axles set up 100% Its time to mount electronics... that should be a fun adventure! Thanks for the help, Bowtie Last edited by Bowtiewarrior; 07-23-2020 at 11:17 AM. Reason: added detail |
07-22-2020, 06:29 AM | #13 |
| Re: Custom Axial SCX10.3 Last edited by Bowtiewarrior; 07-23-2020 at 06:45 PM. Reason: better photo links |
07-22-2020, 09:30 AM | #14 |
Just got my kit last week. It's still in the box. Sounds like you've made decent progress so far. Sorry I can't be more help atm. |
07-22-2020, 09:31 AM | #15 |
Not sure if your post today was supposed to be a pic, but it shows nothing. If you want to post pics. use a site like Imagur to host the pics, then copy the BB Medium Link for the pics and use that link to post in your comment. that will allow the forum to show the pictures. |
07-22-2020, 09:37 AM | #16 | |
I will have to get a Imagur account, and set it up that way. Bowtie | |
07-22-2020, 03:07 PM | #17 |
I used to have Photobucket. But they deleted a crap load of my pics. Because I am OVER LIMIT with their NEW Pay For hosting site. I should sue them under the Grandfather Clause of Contracts. But meh. They are dying and going out of business faster every day. That will have todo. I am using imgbb to host pics here is one of the BB Medium link pics that is somewhat fitting to your post anyways. lol www.imgbb.com |
07-23-2020, 06:46 PM | #18 | |
07-23-2020, 09:40 PM | #19 |
| Re: Custom Axial SCX10.3 |
07-24-2020, 05:24 AM | #20 |
| Re: Custom Axial SCX10.3 Not yet, I still need to sort out the above measurements, I know wheel base is long, and I know the front axle location isn't correct. I reached out to Axial/Horizon to see if I can get some answers and they were NOT helpful, their response was actually pretty lame. I asked about factory measurement based on poor directions on the factory build and not placing the appropriate links in the right location, and they told me that they don't have any measurements, and just build it like the directions say to. I checked with my local hobby shop, they didn't have an RTR I could measure, I might extend my search to surrounding towns to try to find a truck to measure. Hindsight = I should have built it factory THEN modified it after I took the measurements I needed. Bowtie. |
