09-08-2020, 06:41 AM | #1 |
Newbie Join Date: Mar 2012 Location: Brunswick, Maine
| 10-3 RTR adding 2 speed
I've tried searching for the answer with no luck. I have the RTR 10-3 I'm swapping to a 5 channel radio and want to add a shift servo to make the 2 speed functional. Aside from the servo (reefs99) and servo horn is there any other parts needed? |
09-08-2020, 07:12 AM | #2 |
| Re: 10-3 RTR adding 2 speed
Should be no other parts you need (except maybe a few screws), there is a spacer on the transmission shift rod that locks the 2 speed in place. Take that spacer out, hook up the servo, set the endpoints, and you should be good.
09-08-2020, 07:59 AM | #3 |
Newbie Join Date: Mar 2020 Location: Palm Beach County Florida, US
If you haven't already download the manual from the kits so you have it all broken down to see any changes in the transmission that need to be done. Good luck Sent from my SM-N975U using Tapatalk |
09-08-2020, 06:39 PM | #4 |
Pebble Pounder Join Date: Nov 2006 Location: Tennessee
The miscellaneous parts that came with the truck has the screws and servo horn in the bag all you need to do is get another servo just like the dig servo and a servo extension because the leads on the micro servos spektrum sells are way to short to reach anywhere. The micro servo also comes with the splined part that the spring and servo arm slide onto. As stated before the transmission has a spacer inside to lock it into 1st gear. You will have to pull the transmission out of the truck and split the case apart to get the spacer off of the shift arm. As a side note I had a hard time getting the shift servo into place because the wires coming out of the case interfere where the servo mounts. |
10-3 RTR adding 2 speed - Similar Threads | ||||
Adding a WPL 2 Speed Gearbox | Daynger_HiVuhltage | Electronics | 0 | 07-03-2020 08:20 AM |
RTR 2 speed transmission | GR8 PMKN | Axial SCX10 II | 5 | 08-21-2018 01:57 AM |
Adding another coat of paint on a RTR pre-painted panel? | 2-shot | Paint and Body | 2 | 02-27-2016 12:49 PM |
Speed Limiting a RTR | Bueller | Newbie General | 24 | 05-23-2012 01:14 AM |
