09-15-2020, 06:46 AM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: Italy
| Dig and speed shaft
According to the manual the shaft which moves the fork of the dig and of the two speed selector is included in AXI232036 spare part. I checked all the images I could find of item AXI232036 and I can clearly see the forks but not the shafts. I would like to be sure the shafts are comprised because I need them for a custom project. Should I ask Axial directly ? Am I looking at an outdated manual ? Thanks Filippo |
09-15-2020, 04:43 PM | #2 |
Pebble Pounder Join Date: Mar 2015 Location: East coast Canada
| Re: Dig and speed shaft
You mean the little shaft that attaches to the fork and has a rod end that connects to the servo? if so my manual lists that as part # AXI232036 for both the fork and small shaft. This is from a kit I bought 2 weeks ago |
09-16-2020, 11:36 AM | #3 | |
| Re: Dig and speed shaft Quote:
Correct, but on the images I found about AXI232036 the only metal parts are the 2 forks, no shafts. | |
09-16-2020, 12:39 PM | #4 |
Both the forks and shafts are listed as the same part number in the manual.
10-08-2020, 12:29 AM | #5 |
Horizon Customer care finally recognized the error in the manual. Worse still that shaft is not available as scx10 iii spare, if you really need it the only chance is to by a Capra spare. In my opinion it is a really good job from the new deal which is saving too much on instruction manual costs. Here is the visual demonstration that the shaft connected to the dig fork is not inside AXI232036. |
Dig and speed shaft - Similar Threads | ||||
What is the output shaft size on the RC4wd 2 Speed tranny? | e32lover | Axial SCX-10 | 3 | 08-24-2015 09:29 PM |
2 speed trans drive shaft issue | Square-D | Axial SCX-10 | 3 | 03-10-2015 06:31 PM |
2 speed trans w/ drive shaft upgrade | 40 grit | Axial Wraith | 10 | 10-31-2012 04:21 PM |
