10-19-2020, 03:20 PM | #1 |
Rock Crawler Join Date: Aug 2020 Location: In The HIVE
| Axial SCX10iii Honeywagon Work in progress...
This is my SCX 10 three that I finally started upgrading it is a really capable rig mine does not have any of the clicking the people talk about I felt there was a little something and I change the pinion gear to an 11 to harden steel Robinson racing no issues with anything I’m working on getting this rig even more capable got some gearhead wheels on it got the Holmes hobby 540 Tourquemaster Pro and the Holmes hobbies BR XL ESC And. Fly sky GT5 radio Reefs Raw 500 servo and TRX4 shocks with brass cups no leakage... next axles, suspension and more more more...... never ends does it. Buzzzzzzzzzz.... |
11-12-2020, 09:55 PM | #2 | |
Newbie Join Date: Jul 2020 Location: Discovery Bay
| Re: Axial SCX10iii Honeywagon Work in progress... Quote:
11-13-2020, 05:54 AM | #3 |
Rock Crawler Join Date: Mar 2008 Location: Plainfield
Nicely done, sir. Lou |
11-13-2020, 06:51 AM | #4 |
| Re: Axial SCX10iii Honeywagon Work in progress... Hey man they are made by Club 5 RC got them on Ebay they are solid and since im not going to be using the clips on the bottom of the body they keep the body super stiff!!!! im going to put a post on this build today hopefully starting next week to overhaul this beast!!!!!! BUZZZZZZ......... |
11-13-2020, 06:38 PM | #5 |
| Re: Axial SCX10iii Honeywagon The Overhaul Begins BUZZZ...
here are the parts I have collected in the last 3 months I have a couple more on the way but here is the majority of the parts im adding to this BIG BEE..... BUZZZ....... Parts list: Hot Racing( Brass steering Knuckles and Caps Drivelines Front and Rear Shock Tower braces) Fast Eddies SCX10iii (Bearing Kit) Samix (Titanium High Clearance Links) TGH (Portal Axle Gear Set OVERDRIVE & STANDARD) KNK SCX10 iii (Stainless screw kit and chassis and driveline stainless kit) GPM (Aluminum Battery mounts and Front Body mounts) RC4WD (Rock Crawler shocks 90mm) Treal (Front and Rear Aluminum F9 axles/ Shock Body Mounts/ Skid Plate/ Micro servo aluminum horns & overdrive gear) KYX (Aluminum Front Bumper mount/ Front and Rear Body braces/ Side Step Running Boards/ Hard Steel Front & Rear Axle CVD Straight Drive Shaft Dogbone/ Hardened Steel Transmission Gear Set Gearbox/ Aluminum Servo Mount Bracket/ Frame Rail Bracket Battery Tray Mount) Axial (Link Rod Ends set) also the Reefs 500 Raw and Holmes pro motor and BEC stay on this rig.... Ill keep posting as the build progresses!!!! BUZZZZ....... Last edited by Honeyman108; 01-12-2021 at 06:33 AM. |
11-13-2020, 11:08 PM | #6 | |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: Axial SCX10iii Honeywagon The Overhaul Begins BUZZZ... Quote:
That’s a lot of parts man! Everytime I see your Hawaii plates, I get jealous lmao. How are the Hyraxes? I’m torn between the flat irons, hyraxes and BFG Krawlers. I’m leaning BFGs because I really like that scale looking tread pattern. Sent from my iPad using Tapatalk | |
11-14-2020, 05:35 AM | #7 | |
11-14-2020, 10:55 AM | #8 |
Pebble Pounder Join Date: Mar 2015 Location: East coast Canada
Those gears seem like they'd eliminate a lot of the slop that's in the factory gears..... be interesting to get some input for them
11-14-2020, 12:34 PM | #9 |
| Re: Axial SCX10iii Honeywagon Work in progress... Me too just changing the pinion gear to a high quality 11 tooth made any noise go but I know the trans needs help so I will let you know asap ill bee posting the build photos and videos and reviews so stay in the Hive..... BUZZZZZZ........ OM......
11-15-2020, 11:27 AM | #10 |
| Re: Axial SCX10iii Honeywagon TRANSMISSION BUZZZZ......
OK so I posted yesterday the gears and I received them today and took the Tarns apart to see what else I need to buy so I one ahead an got myself a steel spur from KYX and some new slipper pads the stock ones there are pretty toast!!!! so until I get those in the mail and 2 other parts im not gong to start this beast but im sure in a week or two ill get going and start posting!!! BUZZZZZZ........
11-16-2020, 09:42 AM | #11 |
| Re: Axial SCX10iii Honeywagon Transmission Start!!!
Ok going to start with the Transmission then slowly head to the Axles on the next episode keep you posted.... BUZZZZ.....
11-16-2020, 02:54 PM | #12 |
Good stuff here! Lou |
11-17-2020, 06:22 AM | #13 |
| Re: Axial SCX10iii Honeywagon Work in progress... |
01-11-2021, 06:35 PM | #14 |
| Re: Axial SCX10iii Honeywagon 2021 Finally Back to Work
SO finally I started getting back to rebuilding and fully Modding my SCX10 iii.... I have all the parts and the wheels are finally turning on this build .... In this post Im showing the rebuilt Trans/ Side Panels and rails Mounted Treal Axles Treal and Hot racing Brass TGH Portal gears Treal Micro Servo Saver Mounted on The NWSD ST-1 Scale Table... KYX Driveshafts Scalerfab Side Rails GPM Aluminum Battery mounts KYX Trans Gears Set KYX Spur gear Hot Racing pinion gear BUZZZZZZZ........ Last edited by Honeyman108; 01-12-2021 at 06:50 AM. |
Axial SCX10iii Honeywagon Work in progress... - Similar Threads | ||||
1.9 to 2.2 axial scx10 work in progress | minicrawlerguy530 | 2.2 Scale Rigs | 82 | 05-28-2013 10:58 AM |
work in progress very,very slow progress! | rednekcrwlr | Tamiya Clod Buster | 6 | 12-18-2006 09:48 PM |
