10-22-2020, 08:14 PM | #1 |
Rock Crawler Join Date: Dec 2012 Location: Utah
| Simple trick for trans gears shimming
Grabbed a new Gladiator a few weeks ago. Tore it all apart to check assembly on everything and put more grease in preassembled trans. I am pretty picky about such things. Everything actually looked pretty good. The trans just needed more grease on all the gears IMO. The only thing so far on the whole truck I didn't love was the preset gearing/mesh on the motor plate. While it is a awesome idea and pretty genius, The stock 14t pinion was quite a bit tighter meshed with the spur than I care for. I wanted to run an 11t with my brushless setup for super smooth low-end. But even installing a 11t in the preset holes, it still meshed tight with the spur. So I used this old trick I've used on many other applications. A little HVAC aluminum tape was perfect for getting that just right bit of clearance between the gears. How this helps if anyone noticed the same issue |
10-23-2020, 03:39 PM | #2 |
Pebble Pounder Join Date: Mar 2015 Location: East coast Canada
| Re: Simple trick for trans gears shimming
Neat little trick, have to remember this for future use We should have a tips and tricks thread in the scx10.3 forum for stuff just like this |
10-23-2020, 03:53 PM | #3 |
this works for the TRX4 as well
04-23-2021, 02:21 PM | #4 |
Rock Stacker Join Date: Apr 2021 Location: Lynnwood
Thanks for the info! I've been running my RTR but am going to go through the driveline with grease this weekend. Still frustrated with the stupid servo issues though. It was nice having a working 2spd for one whole day. |
04-26-2021, 07:58 AM | #5 |
Oopsie! Over packed the driveline. I need to scoop a bit of grease out.
Simple trick for trans gears shimming - Similar Threads | ||||
Shimming for od gears | Jeepkid | Axial SCX10 II | 0 | 12-28-2017 09:15 AM |
Shimming the diff gears | 95yjsahara | Axial Yeti | 11 | 03-29-2015 06:17 PM |
Shimming the HD Worm Gears | Del Monte | Team Losi Comp Crawler | 65 | 01-12-2012 08:48 PM |
Shimming gears | Josh_Br | Axial AX-10 Scorpion | 7 | 12-23-2011 01:25 PM |
