11-14-2020, 04:36 PM | #1 |
Newbie Join Date: Jul 2020 Location: Discovery Bay
| Static rear ride height
I just added a Hot Racing aluminum rear bumper. I replaced the rear shock oil with 60wt, but the static height leaves only about 1/4 of travel. I have to give the rear a ton of preload to get it to not sag. Do you all have any suggestions? What is the negative effect of running a lot of preload? I am new to the crawler world.
11-14-2020, 05:59 PM | #2 |
Rock Stacker Join Date: Oct 2019 Location: Lantz, NS
| Re: Static rear ride height
My preload is almost turned all the way down, and I also put 60wt oil in it. It still works well on the trails, but I would prefer a slightly stiffer spring just so I could take a bit of preload out.
11-14-2020, 08:53 PM | #3 |
Pebble Pounder Join Date: Mar 2015 Location: East coast Canada
Try swapping the springs around front to rear, I had mine backwards when I built it, swapped front to rear and all is good now
11-14-2020, 09:53 PM | #4 |
Quarry Creeper Join Date: Dec 2019 Location: California
Try new springs. I think Traxxas is one of the few guys that make different stiffness springs options for their shocks, which is part of the reason why I like GTS shocks so much. Maybe try a Traxxas spring, should fit your shock but I cant be sure. Get a couple of stiffnesses and test around for the right one.
11-15-2020, 05:42 AM | #5 |
Axial makes a bunch of different rate springs, but I can't see you needing them, like I said above, once I put the front springs on the front and the rear on the rear all is good. im also running a 4000mah 3s long battery pack in the rear battery tray so my rig is a bit heavy on the rear end |
Static rear ride height - Similar Threads | ||||
Ride height vs static droop? | jeff22 | Axial SCX-10 | 4 | 02-15-2015 04:28 PM |
ride height? | 73fordhighboy | Axial AX-10 Scorpion | 3 | 05-25-2010 07:33 PM |
Ride height | DJCrawlin | Axial AX-10 Scorpion | 3 | 11-13-2009 07:30 PM |
Ride height versus max height | Manson | Axial AX-10 Scorpion | 9 | 10-03-2008 01:26 PM |
ride height | the kid | General Crawlers | 5 | 02-07-2007 09:25 PM |
