Brass knuckle clearances Hi all, An easy mod for better steering angles is to trim the inside of the knuckles -- are there any brass knuckles out there that come pre-clearanced (given that grinding brass is meant to be a pita)? |
Re: Brass knuckle clearances Grinding brass it's very easy. Most of the knuckles that are on the market, need to be grinded if you need more turning radius |
Re: Brass knuckle clearances You could easily file brass also for a more controlled clearancing. |
