01-30-2021, 08:54 AM | #1 |
Rock Crawler Join Date: Aug 2020 Location: In The HIVE
| RCBee Needs Steering Help Buz... Buzz...
Hey crawlers I’m In need of getting longer travel and better steering on my SCX 10 three project finally got everything and all the modifications that I want installed changing a thing here or there and the rig is driving and handling very well but the steering is killing me obviously you get lotta steering to the left and then very little to the right I’m thinking of getting a longer steering link or an adjustable one like the one I’m picturing let me know your thoughts and how I can fix this Situation HELP... Buzzzz...
01-30-2021, 10:05 AM | #2 |
Is your panhard and drag link the same length? Hang up and Drive |
01-30-2021, 11:47 AM | #3 |
Rock Crawler Join Date: Apr 2020 Location: Drums
| Re: RCBee Needs Steering Help Buz... Buzz...
is it mechanically limited (hitting the knuckle stops) or electronic (servo goes as far as it can but not far enough to the right)? One thing I notice is your drag link is reversed. The offset on the links should be the other way. That could cause and add angle that takes away from servo leverage. Also, are those front axle stubs stock length? The look like they out real far from the C-hub axis point. |
01-30-2021, 02:52 PM | #4 |
| Re: RCBee Needs Steering Help Buz... Buzz... |
01-30-2021, 02:56 PM | #5 | |
| Re: RCBee Needs Steering Help Buz... Buzz... Quote:
Yup good eye on the draglink it is reversed did not notice at all !! Buzzz... They are 10mm offset hot racing axle stubs but I don't think they are causing the problems but did think to going back to stock length. stubs.... Thanks for the info and let me know about the longer steering link? Buzzzz... Last edited by Honeyman108; 01-30-2021 at 02:59 PM. | |
01-30-2021, 03:04 PM | #6 |
Pebble Pounder Join Date: Feb 2017 Location: Louisburg, NC
Sounds to me like you need to center your servo.
01-30-2021, 04:02 PM | #7 |
01-30-2021, 06:26 PM | #8 |
If you hold the front wheels off the ground as a test, can the servo get a little more travel?
01-30-2021, 06:40 PM | #9 | |
01-30-2021, 08:05 PM | #10 |
01-30-2021, 08:15 PM | #11 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
Glad you got it sorted! _________________ SCX10 ii TRX4 |
02-18-2021, 06:48 AM | #12 |
| Re: RCBee Needs Steering Help Buz... Buzz... Aloha Scale!! Yes the Steering is good and solid!! Now the Thorn on my side is the Panhard Bar length and adjustability!!!! Im learning a lot and also appreciating my TRX4 more than ever for its versatility I thought the SCX10iii was going to be as easy to fix modify and tinker as the TRX4 and was wrong but again im learning a lot!!!!! Mahalo...... BUZZ... Thats my Slash ultimate with Bug body!!! Also im selling my Hawaiian 2wd Slash as I have too many projects and have to give something up check it out!!! https://www.ebay.com/itm/23389029729...84.m1555.l2649 |
RCBee Needs Steering Help Buz... Buzz... - Similar Threads | ||||
RCBee Buzzing to See your Hobby Room/Workshop/Bench | Honeyman108 | Chit Chat | 6 | 02-03-2021 10:39 AM |
RCBee Needs HoneyWagon Help Axial SCX10 iii | Honeyman108 | Axial SCX10 III | 19 | 01-17-2021 08:23 PM |
Motor buzz, what causes it? | Asuckaphish | Electronics | 2 | 08-09-2016 09:00 PM |
Bday buzz | braceysdad | Chit Chat | 13 | 11-24-2010 10:30 PM |
Why would a battery buzz???? | CrAwLeR13 | Electronics | 8 | 06-28-2010 09:59 PM |
