10-10-2022, 08:10 AM | #1 |
Rock Stacker Join Date: Apr 2021 Location: Lynnwood
| 4in Lift
Hey, Folks. I have had the straight axle kit for a while but have been slacking on trying it out. Mainly the need to lube the seals with slime and paint the stupid red diff covers. I get it that it is Axial's thang, but just not for me. I've done similar stuff on my real truck that makes friends laugh. The main reason that I got the kit was for the 100mm shocks. Yeah, I know. Axial shocks suck and there are less expensive, better ones for much less. But, I did want to play with the straight axles eventually. 55wt oil seems to perform well and keep the big drips at bay. I only had time to set them up, rebuild the stock ones, and paint the diff covers yesterday. But, it looks like the longer shocks serve as better bump stops at full flex. Mission accomplished, maybe. I suppose my biggest gripe overall is that the body uses those big, interfering lugs to attach the fenders. I'm not a fan of 1:1 Wranglers with aftermarket flares, so I am trying to not do that here. I think it would have been cool if the flares attached to the wheel well liners instead of the body? I'll give it a run in the next couple days and post up pics. Hoping the front drive shaft has enough spline. Hahaha! |
10-11-2022, 09:19 AM | #2 |
| Re: 4in Lift
I should have taken Before pics. But, it looks like I mainly added a scale 4in of down travel, which is great with me. Before: https://photos.app.goo.gl/3b5K4eRumvyRmz7Z9 Current: https://photos.app.goo.gl/VU73NpXicEe5R11e9 Last edited by tonered; 10-11-2022 at 09:24 AM. |
10-14-2022, 05:34 PM | #3 |
Newbie Join Date: Sep 2022 Location: Hudson
| Re: 4in Lift
Looks pretty good!
10-17-2022, 07:51 AM | #4 |
| Re: 4in Lift Thanks! Got it out around the house on Saturday. Climbed obstacles a lot easier. Where I had to set a good line in the past, now it just didn't care. And less rubbing when flexed. Although, slightly more likely to roll off camber. The full interior is in, but I think some of the is due to the extra stroke in the shocks giving the CG more room to move in the bad direction? Haha! I hate to say it, but it was worth upgrade. Gonna be hard to swap in the straight axles. |
4in Lift - Similar Threads | ||||
Proline 4in LED not bright | larrymuld | Electronics | 4 | 05-15-2018 10:05 PM |
anyone running 4in. shocks | mini freak | Axial SCX-10 | 6 | 12-24-2011 02:25 PM |
