04-19-2011, 09:50 AM | #1 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
| what's different bout wraith axles..........
ok i have been seeing talk bout the axial wraith axles....how are they different from the AX10 and SCX10 axles they make....yes i did a search but no pic's to see the difference........bob .... |
04-19-2011, 09:52 AM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
offset center drive gears an pupmkin.plus the case itself on hw its pulled apart.u probaly could get some info from axials website if needed
04-19-2011, 10:15 AM | #3 |
if you looked in the Wrath thread you could see lots of pics of the axles.
04-19-2011, 10:17 AM | #4 |
04-19-2011, 12:05 PM | #5 |
RCCA has an article about it. It looks very easy to change the diffs from locked to open and back, you don't have to rip the entire axle apart.
04-19-2011, 01:40 PM | #6 |
Quarry Creeper Join Date: Sep 2010 Location: Berlin, VT
From the link above. Front And the diff. |
04-19-2011, 03:09 PM | #7 |
04-19-2011, 03:20 PM | #8 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
they are also about an inch wider than the old axles. i wish they would come out with that design at the stock width.
04-19-2011, 03:31 PM | #9 |
Rock Crawler Join Date: May 2009 Location: 354
04-19-2011, 03:49 PM | #10 |
04-19-2011, 03:51 PM | #11 |
Pebble Pounder Join Date: Sep 2009 Location: "the valley"
04-19-2011, 08:13 PM | #12 |
04-19-2011, 08:37 PM | #13 |
hey thanks guy for all the info....i read the wraith thread but not much of it....non of the pictures i seen were at bad angles when i went back to look at them....i can see with the off set center the driveshafts being inline more........bob .... |
04-22-2011, 03:04 AM | #14 |
Pebble Pounder Join Date: Oct 2009 Location: Australia
04-22-2011, 03:17 AM | #15 |
Quarry Creeper Join Date: Sep 2006 Location: Orange, CA
04-22-2011, 03:25 AM | #16 |
Some other differences not mentioned here: C's and knuckles - these are off the XR10 and are pretty strong and durable, pus they allow more adjustment to caster angle, also the optional Universal axles will be similar to the XR10.. again strong and durable, plus lots of steering angle when using these option parts zero ackerman - with locked diffs and the steering link in front this helps the steering angled kingpin design, this helps reduce scrub radius when turning which is a lot easier and better on a servo, as well as aids in high speed steering. When you have lots of scrub the truck will want to dive forward and flip when turning under speed. suspension geometry - these are set up for 4 link vs. the old 3 link, also the lower link mounts can be flipped to adjust the position of the lower links and shocks All the above items make them really good for use on any custom build rig, especially if you are looking for a wider stance and want to maintain better steering and handling. |
04-22-2011, 05:34 AM | #17 | |
04-22-2011, 06:04 AM | #18 |
Rock Crawler Join Date: Dec 2005 Location: Connellsville PA."fayettenam" lol
04-22-2011, 09:05 AM | #19 |
| At 243 mm hex to hex, they are about 30mm wider than WK axles when I measured the WK's under my Willys, a bit too wide for my tastes but I'll be one of the first to attempt to modify the width of these axles to use under the Willys. |
04-22-2011, 09:44 PM | #20 |
No word yet on axle sets just yet.. I am just focusing on getting the complete RTR finished and shipped at this point.
